honda civic 1.8 or celica
borland
9
dear sifu's...
rite now my father want 2 get me a 2nd car... n my budget is between 80k-90k...in my head now is honda civic 1.8 (year 2006) and celica 6spd (M)...rite now i'm 23 and still have 1 year in study...i really love sport car...huhu.. :driver:
can ur guys give me some opinion which car should i buy n also detail bout dis car...it's easy or hard 2 maintain n also it's easy 2 find the spare part...n also bout the using in fuel...which 1 is more saving...
really appriciate ur help.... :shakehands:
ACQ2305
988
184
HeadHunters
civic, ES model FD? given d 2 choices,i'll get the celica,its a manual..but engine,not so potent..plonk in a 3SGTE..
unless the civic,has a B18C inside..
DarkAccoon
880
432
3,063
a FD3S is good
65k, then still got 25k to fix up everything and it is a real looker compare to those two cars.
biz-da-tech
520
civic is more modify and more u can go.
celica just like that normal as usual lo..
but talk about which car is more easier to see on the road. CIVIC lo. and celica is not that much.
look celica slightly a bit better .
but fuel i think both are almost the same.
and more hardcore performance car. is civic :)
steven7810
mivec user
1,314
26
kuala lumpur
i personally will go HONDA CIVIC 1.8 OR 2.0 IF SECOND HAND CAR WILL GO CIVIC BUT WITH B SERIES ENGINE B16A B16B B18... K20..
I PERSONALLY USING MIVEC ENGINE 4G92 MANUAL...
IS BETTER GO FOR 4 DOORS CAR EASY TO FETCH PPL...THINK IF U MARRIED....
allance
337
if u want look like sporty , ocus the celica ,celica have 2 model engine (VVTL-I / VVT-i engine)
VVTL-i model is like i-VTEC typre R engine(they caller by economi n performance engine)
VVT-i model is same as altis use 1.8vvt-i engine
borland
9
what is civic ES model FD...? what car always use 3SGTE...?
altezza also not bad i think
thanks 4 ur opinion
a FD3S is good
what is FD3S...? it is honda 1.7...can u show some pic of this car...thanks...
thanks 4 ur opinion...
can honda civic 1.8 inserted engine B series...?
which 1 is more power.... VVTL-i or VVT-i....can celica engine upgrade so it more power like honda engine...?
Bump: what i mean honda civic 1.8 (2006) is honda civic fd...sorry for misunderstanding...
allance
337
thanks 4 ur opinion
the pick up is to close btween VVTL-i n VVT-i , but when at high rev RPM VVTL-i engine (LIFT/ VTEC) is open ocous can overtake the VVT-i , ( VVTL-i engine oso can upgrade like honda VTEC bcos they have use same (Valve timing n lift system) all upgrade is up to u if u kaya:top:
honda civic 1.8 i-vtec what u mean the i-VTEC system just program for fuel saver is not program for race engine or power full like B16B/B18c engine(VVTL-i u can feel the power like VTEC red top cover race engine)
borland
9
oic...how bout fuel for VVTL-i...it's same to i-VTEC rite...?
the spare part for celica is easy or hard 2 find...?
how about the maintenance...?
ettm_14
605
81
bro for me i think just go for civic, it is much newer compared to celica 2006, i dont think you can get a 2006 celica for 90k, second modding celica is like putting money into a black hole, you wont be satisfied untill you do an engine transplant,
third, civic is 4 door and can fetch more chicks, can slighty mod then you are on your way edi,
just my two cents
borland
9
just my two cents
can i-vtec upgrade so it can be more power...?
allance
337
if new civic 1.8 i-vtec is fuel save than celica VVTL-i,i told u liao... new civic 1.8 i-vtec is program for maximun fuel save n smooter performance only , if u target buy the celica n think about for fuel saver u can choice VVT-i engine is make for fuel eco n smooter performance too...:proud:
The spare part for celica dont worry about this, is eazy to find,n maintenance is like honda bcos all is come for japan , cheap than buatan malaysia!
if uthink for farmily car, better u get civic lo...4 door ezy rear passenger out or in ,if u want to action on road choice the celica :driver:
Bump:
can! bolt on turbo!!!!!
if u just want upgrade for stock engine olso can , but just a bit power up (around 5whp-15whp),if light boost turbo (25whp-50whp)........max boost for this 1.8 i-vtec engine is 0.5bar max so far safely
borland
9
Bump:
thanks 4 ur information man...by the way what is ur car..?
allance
337
if on engine is 250bhp, on wheel got 193whp set on 0.5bar of boost,get the high boost coming soon! (300bhp or more):proud:
how fast? i test on dyno can go around 240kmh up( b4 this u need install speed limit cut frist)all japan car speed limit is only 180km/h:thumpdown:
bikerz
213
2
bro, urs is auto or manual? 0-100 how many second? mine is auto planing to bolt greddy supercharger
allance
337
mine is auto with sportshift! 0-100kmh in 9.sec (all stock is 12.6 sec)
gsrTurbo9166
958
TS,
since u wan sportcar n don mind bout 2nd hand. celica manual is ur choice. get the super strut edition. although it is expensive to replace the suspension but the handling is way better than normal 1.
if u plan to drop a K20A type r engine to the civic, then juz get civic FD. furthermore it is 4 doors as others said, can fetch more chicks :biggrin::biggrin:
Hi bro allance
r u the 1 from perlis wif SC?
do u know who is alan? the orange celica
im driving celica too. yellow color manual. hope u heard bout me b4 from alan
any idea when u r coming to penang?
long time din TT wif the celica kaki d
Dear all,
I've been bothered by this for quite some time, as far as I know,
ignition advance would mean moving the ignition timing further away
from BTDC and retard would be getting it closer to BTDC. After
referring to most of the maps uploaded here, I've noticed that most,
or rather all the maps that I've seen had their ignition timing
retarded. I've sent my car for dyno tune recently and the tuner
advance all the timings from 3-6deg. I gained only about 2hp with
this...
