how to increase l2s top speed??
spoiltbrat
97
if any sifus here can tell me how to increase l2s top speed... my car still stock l2s only.. thanks...
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
oredy remove the speed cut?
a lot of L2S/5 owner who chases top speed love to modify the gear ratio... some just use kancil 850cc final drive only
spoiltbrat
97
sorry.. forgot to tell that my l2s is auto one... btw wat is speed cut??
spoiltbrat
97
top speed on road currently is around 146km... feel very slow.. i saw one member from zth can reach 170-180km.. how to achieve that speed??
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
when you reach 146km/h, do you feel like the engine losing power i.e... the push is lost somehow? if so, then the speed cut are not remove
FYI, kei-car speed limit suposed to be 140kmh....give or take a few...
I think you need to remove the speed cut first..easy if using apexi rsm, pivot speed meter etc.... some pomen oso tells me that you can remove the cut without gadgets mentioned by do some wiring to the ecu...
what is ur rpm at 146kmh??
got the gear ratio, tyre size and max rpm limit (see ur speedo)? I can calculate it via my GearCalc software....
SYeNi69
402
47
TTDI KL
dangerous la bro going at that speeds in a kancil ...
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
speak for ur self....ur car's a speed demon :adore:
....err r u the same syeni as in kcarlife? :hmmmm:
SYeNi69
402
47
TTDI KL
MAYBE ... kekekekeke :wavey: ... it doesnt hurt giving advice :biggrin:
Well here's my opinion ... 180kmh is possible with an auto L2 ... my car started life as a normal L2 auto untill i met some friends that are otak 3 suku :rofl: ... and when it was stock i removed the speed cut using RSM and increase the boost by 0.9 using gud ol "tulang ikan"... :biggrin:
clocked my RSM 18+ kmh ... but thats electronic ... i dun think its faulty ... but then i might be wrong ...
anyways drive safely ...
:biggrin:
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
can say so... coz if at 146kmh, tacho already at 6k rpm (assuming no clutch slip), means ur top speed is limited to gear ratio...
if ur max speed is 146kmh @ 4k rpm or so, ur max speed is limited by ur low engine output....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
:biggrin:
even if u use different tire size/profile, the speed difference is +-10kmh only.... still fast man :adore:
for me, after 130kmh already scared me.... that's why i dun wan to remove the speed cut :slug:
spoiltbrat
97
i dunno abt the gear ratio... if not mistaken the RPM for 146km is around 5500.. my car rims is 165/60/r13..
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
well i do have L2S manual gear ratio (5 speed)... the general idea is that an auto version of the transmission knock off 10km/h from the manual version top speed.
if i'm not mistaken, L2s engine (EF-JL) produced max hp around 7500rpm right? and the rpm limit are at 8500rpm?
refer to attached txt (do view it fully maximize, if not the viewing format skewed)....
you can obtain the software by downloading it here....
http://locost7.info/gearcalc.php
can calculate once u get
  1. your gear ratio including final drive
  2. RPM reading when the engine produce max power
  3. your engine rpm limit aka the redline
  4. tyre size and profile
p/s: L2S and L5 ratio virtually the same, just the final drive a bit different...L5 final drive ratio is 5.071
spoiltbrat
97
i just recently changed the engine... bt 1 month... so the ATF still ok i guess... and i will test again then i'll update.. dohelp me with it.. thanks... and wat do u mean gear ratio and final drive ratio??? sorry.. not good at it...
Hi to all sinfus, my current 4 tyres is running bold soon n m looking for cheapy tyres. As i ask from the shop for 17" cheappies, the taukeh intro me Kenda Kaizer, but i've never heard it before. Got anybody is using the tyre currently? pls do leave some comments on it if possible whether its the best bang for bucks. thanks.
