have any 1 transplanted ED-DE(kancil ezi) ??
rotaryfans
46
newbie here
I m juz wandering if the kancil auto dohc engine can transplant into kancil ?
or any1 with kancil ezi swap with 5mt ?
mR ad
1,560
off corse bro it can be done..same mounting and base bro.......
but make sure u have all the wiring also......
and from ezi to 5mt......also a lots of kancil owner done it ardy...me also bro:biggrin:
mag9556
2,770
43
1,648
newbie here
can.. but mounting need to modified a bit.. wont harm even JPJ inspection also no problem...
try it before as my L5 engine just like 850 DOHC Auto at the end change back to Auto.. better...hehehehehe...
make sure endorse geran lol.. Good Luck..
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Can you :adore: please elaborate on how its done? I'm EZi owner oso...but some say to use kancil 850cc MT, need to mod the flywheel? How about the driveshafts, need to change oso? the cost?
some ppl sez its easier to source kelisa 850/1.0 gearbox + shafts...izzit true...
waaa....thanks a lot for opening this thread...me been searching high and low... :adore:
mR ad
1,560
to modd an EZi to 5mt 850cc......
make sure u buy the gearbox complete wth the flywheel bro.....
and off course u need the shifter and padel also complete wth cabel....
usually 850cc gearbox cost bout 400-500.....
clutch padel and shifter bout 100-150...this is roughly budget....
changing the gearbox usually rm250 - rm300 depends on ur workshop...
rotaryfans
46
i m the exi owner ..
how much does the ed-de(dohc) cost ??
half cut ??
is it as expensive as L2 half cut ??
personally prefer Na engine
n how bout the FC ?
thanks for explanation
mR ad
1,560
if u using 850cc kancil....better go for kelisa or kenari engine...
best maa 1000cc in kancil...
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
thanks for the input...meaning my pomen was right all along... :rofl:
bettter yet, get those myvi 1.0 engines...lotsa myvi owner ditching dem for k3-vet...dvvt maaa :biggrin:
mR ad
1,560
yup...but im not sure myvi 1000t engine can be fix in kancil or not...
anybody had experience done ir before?????
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
not sure...but I know its uses 3 mountings...just like kancil n kelisa...
I've got this terrific deal...1.5k for the engine and gearbox...but when trying to get more info about the fittings...it sold oledy :shot:
All sifus,
I plan to go with S90 @ 70mm throttle body and aftermarket aluminium intake manifold to match with my Deratech cam.
Meanwhile, is upgrade on air flow meter is necessary?
If needed, what is the air flow code number is good to upgrade?
Also, changing in bigger air flow meter will make the engine run lean ?
Please advise and educate... Thx.:adore:
