bolt on turbo for my car
shashitharan
14
to all sifu's cani install a turbo tp my 4g92p soch.. please advise me wat should i get if can bolt on.. my engine is using 4g93 pistons
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
change ur piston to gsr 1.get a thicker metal gasket,look for td04 turbo incl
manifold for direct bolt on,get a better fuel pump n fpr,i/cooler,bigger injector
and a piggyback to manage ur fuel n ignition.what else.....:hmmmm:
anyone else wants to add?
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Erm, bigger exhaust? colder spark plugs? custom intercooler pipings? how about stronger internals for higher boost? grippy clutch plate? dyno tune? :hmmmm:
karl5511
1,014
Block? No need to change? Or 4G92 block already got oil squirter.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
imo,it's not necessary if ur boosting below 0.8bar.there's a few 1.6 bot
running around w/o it.if got,better la.:)
BananaBoyz
217
we got full metal gasket for 12v 4g13/15 rm240 1.0mm....semi metal mmc 2.0mm rm175....name it what you want...intercoler,injector or custom banana...we dont this project
shashitharan
14
hw much will cost to buy all the stuff mentioned..can i dont use a piggy back
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
there's 1 runing w/o piggy.other's i'm not sure.ur engine is running on maf so
it's much more easier to bot.
sanygsr
181
Hi there..
Better u find completed gsr 1.8 turbo head + turbo + gsr intercoler + turbo host and metal gasket . Now cos around 3 k if u lucky...last time coz around 1.5 k. Then add external fuel pump + e-manage.
done.....
Or 2nd option, find gsr injector, gsr turbo completed with maniful , metal gasket, turbo host, intercoler, external fuel pump , e-manage.
done
Then 1st optionu will get twin cam turbo and 2nd option u will get single cam turbo.
main thing is money.........
gud luck bro
korupted
158
hie there..
mine is 4G15, m planning BOT for it b4 i change to a bigger capacity..wht do ya'll recommend me?wht r d thing i need?
Not 'brake pad dust'.
This one is 'brake DISC dust'.
Happens when brake pad already worn, metal part of caliper touched surface of brake disc, resulting in brake disc getting scratched. Metal dust.
Anybody knows how to remove?
