Alignment, Balancing, Nitrogen, Pumping of Camber
baby_jap_wawa
2,802
Hi. Would the ZTH members share their pricing regarding this services below. I don't wanna get cheated so i would appreciate your help. My car is perdana sei.
How much is it for :
Pumping Front Cambers
Pumping Rear Cambers
Alignment
Balancing
Nitrogen
I would really appreciate your help for these info and let it be shared so that people out there won't get cheated.
Do quote me the price for pumping of front and rear cambers for perdana. Thx. :)
boyzone
2,669
5,148
Pumping Front Cambers -- RM 15 per side
Pumping Rear Cambers -- not sure
Alignment -- RM24 ( Front & Rear )
Balancing -- RM4 per rim
Nitrogen --RM 5 per tyre.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
how do u pump the cambers??... can teach me??..
baby_jap_wawa
2,802
i'm not too sure too..
btw.. is pumping front and rear camber really that cheap.. ?
the workshop quoted me rm195 for front and rm100 for rear on my perdana wo.. ?
jinkl
4,623
376
3,183
baby_jap : hahaha , u got conned
boyzone
2,669
5,148
I had been done 1 time on camber pumping..
actually, it would not last long as the method is using a small jeck to push in / pull out my absorbar.
Better go to camber nut.
Besides, 1 or 2 degress offset in the camber should not given u any problem one.
Just my opinion.
baby_jap_wawa
2,802
what is camber nut.. ?
seanlee
382
3,018
normally we call adjusting the camber nut.....yes it can as cheap as RM15 perside rear....it can be FOC as well...
all depend on the reputation of the shop.....i been recomend by R3 racer in the Klang doing al above thing..but cost hundred above...but result...was good...each tuning has it own behavior ..
tips:
remember..while doing camber or alignment...you have to seat in the car while doing...to be more accurate.
baby_jap_wawa
2,802
0h.. where did u do it.. ? i wanna pump the cambers because my tayar inside makan banyak lo..
jinkl
4,623
376
3,183
wht the hell is pump camber, frm just now u r mentioning , please introduce us to this first time hearing method la :) if its real , i wanna know also
boyzone 1-2 degrees ? r u sure
y dnt u try , front left -1 , front right +1 lolx
rear left +2 , rear right -2 ,
hehehehehhe , gone
boyzone
2,669
5,148
What I mean is :
left :0
Right 1.xx
will not give u significant wear off as might need to consider on tyre pressure and car floor clearnace.
I have notices that my camber always offset 1, 2 degress when do alignment.
But my tyre still wear with very even.
Regarding an oldman from tyre shop told me, camber will be out once we are hit on uneven road surface but not until tyre uneven wear.
If observed any uneven wear off on the tyre, item need to check is not camber setting only, but need to go to btm chasis checkng as any of bush wear out ,lower arm bar bush wear out or weak on absorbar might cause tyre wear one side.
Anyway, go to adjustable camber nut is better insteasd of pumping.
correct me if I'm wrong. :biggrin:
karl5511
1,014
Bros, adjustable chamber nut RM45 per pcs, is it too expensive?
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
sorry to interupt... but anyone kind enough to share any pics or view or thoughts on how pumping camber works??.. means u are pushing ur camber by force??...
baby_jap_wawa
2,802
how much is adjustable cambers for perdana front and rear.. ?
and i think pumping the cambers means pushing the cambers lets say 1-3 degrees.. my area quoted me ard 200 for front and 100 for rear which i think is damn expensive.. since hitting the roads will unalign the camber.. no point i spend so much and suddenly go into one hole the camber zhao yong.. right?
boyzone
2,669
5,148
yes... camber will out once hit to the uneven road surface. Especially high speed hit on uneven road surface, low profile tyre... This word is from tyre shop expriance worker.
baby_jap_wawa
2,802
0h.. means its not reali useful to adjust camber.. ? how abt adjusting alignment.. ? is it a must.. ? and how onli alignment will zhao yong.. ? hahaas..
jinkl
4,623
376
3,183
nah , most of u guys got it wrong, if u hit an uneven surface , doesnt mean it has to give way , first do know how camber works , do u all have first hand in setting camber ? or u guys speaking from other ppls saying :)
camber is adjusted via a bolt and nut which is holding your suspension shocks , here is the picture
i adjust camber on my own , and there will no reason to give way unless you run a "cheap nut and bolt" , "nut and bolt which is loose"
maxwatt
46
Jinkl, great info :congrats: . Have been following the thread for some time.
Some noob questions. By default, is the bolt and nut come with the car? If not how much to get it install?
Thanks bro
jinkl
4,623
376
3,183
Thanks bro
some cars yes, some cars nop, not all car system camber is adjustable :)
as for mitsubishi'/protons , its only rm 15 a pair of camber nut n bolt
Stylo International will be joining hands with the 2011 Malaysian Formula One Petronas Grand Prix as a base to take the Malaysian leg of the Ford Models Supermodel of the World search to the next level.
The winner will get the opportunity to represent the country at the finals in New York City and be in the running to bag a contract with Ford...
