Voltage Stabilizer recommendation
mlanun
6
Hello All,
I'm new here.
Need some advice and suggestion for voltage stabilizer.
I have looked around and found 3 voltage stabilizer that suits my budget.
1. zaptor, silver or gold
2. deizin
3. k2 power
Deizin VS includes grounding kit for almost the same cost of zaptor gold.
One thing that draws me towards zaptor gold is the waterproof feature and 1 year warranty. Deizin only carry one month warranty.
I could not find anything on k2 power voltage stabilizer.
Genuine Pivot Raizin is out of my budget.
I would appreciate any input about this.
boyzone
2,669
5,148
actually, all the voltage stabilizers are same one... the different is brand and model.. and u even though can DIY if u are electronic back ground people.
Btw, u can feel the different after install ... but not for all engine.
mlanun
6
Thanks for sharing.
How about the quality and durability difference?
I wouldn't want it to die so fast on me.
Vagabond
1,731
53
1,648
I still recommend Pivot Raizin.
if you shop around, you can get the original for under RM300, inclusive of installation.
hAz
397
2
true...i bought my pivot blue for rm150 ...
Vagabond
1,731
53
1,648
But be very careful regarding imitations. I've seen plenty in the market.
check out Pivot's web site on how to spot imitations.
Bobby_87
6
using raizin vs.......not bad...but works mostly on the headlight dimming only.....not a performance upgrade woh.........:_:
m@ttz
1,846
13
klang
my clock become blur when switching on the light, headlight also sometimes blinking, do i need vs or my batt was weak?? so far no prob to start my car..
mlanun
6
thanks guys for the input.
k2 or denzin is bad......denzin is the fake 1 from Pivot raizin & its made in Tw...
JINEIL2EN, could you explain how bad they are? I know deizin is the imitation of Pivot Raizin. It's good if you could share your experience.
I'm not sure if it is really worth it to spend more to get Pivot Raizin. Zaptor Gold seems to have quite a good reputation.
huakenny
LB Performance
9,126
240
Kota Kinabalu
1st of all, how much is K2 and Deizin?
i guess the price is slightly cheaper than pivot or zaptor only.
for Pivot, u hv to get from N1 Racing located at sunway to prevent any imitation unit.
since there is an original product out there, why wanna take risk to test the fake/imitation one? it may not bring you any effectiveness perhaps.
so far in the market, the most common we can see is pivot blue n zaptor.
my2cent
mag9556
2,770
43
1,648
my2cent
haha..good thing are not cheap, cheap thing will effect quality...
imitation...sucks...hahaha...
Greytezza
1,130
68
1,648
Truly Asia
I agree with Vagabond..get either Pivot Raizin Blue as it is the most value for money voltage stabilizer in the market. You can install the Pivot without the ground cable first(RM150). Then install the ground cable when u have the budget.
I have it on my car and it does improve the lights and starting.
Vagabond
1,731
53
1,648
.... just don't end up a Pivot addict like me .....
.... first it was the blue .... then the red .... then the yellow .... then the black ... then spark earth .... then ignigtion earth .... then the 3-stage shift lamp ..... then then radiator cap .....
PIVOT ROCKS!
mlanun
6
Does it do much difference for VS between with and without grounding cable?
For the cable, any specific brands that I should look for?
TIA! :_:
zzainudin
503
Subang selangor
yea me too, now searching for better 1 volt stabilizer..
1 more question, what is different between included grounding cable & without grounding cable installation?
thanks
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
simple....just spend some money on it, install it follow all the instruction...make no mistake....after 2 weeks, i just an routine to checked my water level, saw the inside of Denzin seems like been burning b4....wah...the Denzin is buring b4....without any warning....so scary now...dun dare to buy those imitation product liao....especially electronic stuff.....
Don't get too excited, this is not a production car but just a prototype. Now that we have got that out of the way, lets get back to some wishful thinking. Volvo's are generally thought of as boring, boxy and all about ferrying the older generation safely across where ever to perform their elderly duties. Well just about, if you disregard the iconic 850R and the fact that Volvo has and continues to...
