Callin' 4G61T Owner - Wanna Up boost @ 0.8
kk9972
242
Hi all 61T master,
I still cannot forget the feeling / excitement when I newly bring my car out from garage with 1.2 bar boosting in the street. After that successfully reduce the boost by installing new hose for actuator currently having my stock engine boosting @ 0.5 bar.
Now, I'm feeling itchy and want to up boost @ 0.8 bar (Enough for me as I'm fuel-consious person) and need master's advice for me what to do. Just simply up boost? Or what do I need in the first place in order to do so?
Thanks a lot in advance. :_:
kk9972
242
Hi all,
Means that stock engine can withstand @ 1.0 bar without problem? What about long run?
kk9972
242
Hi Zurinazwan,
Thanks for your information. That's very helpful. I'm impress what you did, that's awesome!
I've got your number stored. =) Anyway, where you from? I'm from penang.
Actually for my concern, I don't intend to up boost until such high althought that is very exciting. I'm fuel consious people you knows... haha...
From what you did and your experience, do you think that is fine enough if I just up boost until 0.8 without any modification?
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Hi brothers,
I am on the same track too. Want to up boost but in doubt.
Will be good if i install a Exhaust Gas Temperature gauge and Air Fuel Ratio gauge to monitor my engine first before going for the fuel pump and so on?
I am like you too bro, raising little boost only. Since sifu said that raising 0.2 to 0.3 bar on standard engine would be okay, i am not stepping into the large PSSTT yet.
Thank you.
kk9972
242
Hi Ken,
What engine is in your monster bay?
ken12292703
1,542
5,138
SoMeWhErE
Hi Ken,
Hi bro, mine is a standard stock B8 engine. It's not a monster :confused_smile: . How i wish i can call it monster. :X-: We wait all sifu here help us then can become monsters. :regular_smile:
khoyos
2,632
156
5,163
Shah Alam
kk, so previously u were boosting 1.2 bar, were u worried?
anyway, to answer ur question, if engine 100% stock, with healthy engine, healthy fuel pump, everything in good condition, 1 bar is the max tolerable limit. beyond 1 bar, still can but risky already... so 0.8 bar is nothing.
p/s but if anything happen, dont sue us ar, we dont know whats the condition of ur engine. some people boost 2 bar no problem, some standard boost also piston melt... depends on ur luck...
ken12292703
1,542
5,138
SoMeWhErE
ken,so how high ur boosting now?
Boosting at 0.9bar minimum; turbine changed bigger by previous owner. Unless put wastegate then only can lower the boost. Scary to boost 0.9bar as i have no confidence yet. I have no monitoring gauges as well. Now always vacuum drive. :confused_smile:
ken12292703
1,542
5,138
SoMeWhErE
Thanks for the advice bro. It means that it might still can tolerate the boost generated. Agree with you, every car is different; like humans. :confused_smile:
Hi,
Wat i mean is those manual cars' engine can be start if we engage 2nd gear then push the car to gain momentum then release clutch n press the gas pedal to help then engine rev.
But auto cars dun have clutch, so how do we do it? izzit from N shift to D2 after gain momentum?
