Weits I am not hoarders la. I will try sell things I don't use.Both fellas also greedy hoarders
maybe both of you can exchange 2 wheels. hahahaha....You use back ori then sell your advan to me la.
Are Evo kakis like that......hahhahhahahahhaaBoth fellas also greedy hoarders
That lsm1991 fella is the worst culpritAre Evo kakis like that......hahhahhahahahhaa
if you’re happy and you know it hog some rimsnothing, i just wanted the originals.. i thought can simpan je, just cause i want em....
I've sold many of my unused stuff la, turbo, manifolds, exhausts, intake, rims and tires etc2. Only left things I plan to use or nobody wants already. Need money to partially cover for other parts I still want.Are Evo kakis like that......hahhahhahahahhaa
u pun termasuk?Are Evo kakis like that......hahhahhahahahhaa
eii eii, i havent hoarded anything.....That lsm1991 fella is the worst culprit
Mine not mentioned Evo, Great, great ,great grandpa of Evo......hhahahhahahau pun termasuk?
Well i got the weight info from Sparco's website. In real life when i lifted it, it's really which can i use both to do laterial raise easily. The original rims on the other hand, i can't even lift it with one hand easily. Have to jerk abit to lift it up.Actually I doubt the Sparco is as heavy as 23lbs if it's much lighter than the stock Lancer 18'. I suspect it's closer to 20lbs and the Lancer stock rims should be around 23-24lbs.
Lift weights bro. Bench press and curls. HahahaWell i got the weight info from Sparco's website. In real life when i lifted it, it's really which can i use both to do laterial raise easily. The original rims on the other hand, i can't even lift it with one hand easily. Have to jerk abit to lift it up.
Not very hardcore on lifts nowadays. Wifey said i am too bulky and head look small lolLift weights bro. Bench press and curls. Hahaha
I hope it’s the head I think you’re referring to.Not very hardcore on lifts nowadays. Wifey said i am too bulky and head look small lol
Ya the weight difference is just at the border of your arm strength!Lift weights bro. Bench press and curls. Hahaha
Head that houses brain, eye, nose mouth, ears and hair :)I hope it’s the head I think you’re referring to.
hahahaha
Lucky you mentioned nose and ears. Some people have their brains on their other headHead that houses brain, eye, nose mouth, ears and hair :)
Well ........ alot dudes think with the other head. I house my brain up high lolLucky you mentioned nose and ears. Some people have their brains on their other head
when my brain is up high cannot think. Then will usually do stupid thingsWell ........ alot dudes think with the other head. I house my brain up high lol
Hi 66 is what units? pounds/feet or what ???mamamia said:Hi Accoustic,
I got it! 66/34 F/R weight distribution for an N16....what do you think if I try to reduce the front from 8kg/mm to 6kg/mm ?
Your comments are appreciated. Thanks!
