Civic radiator
that time i dont have knowledge about thermostat. so, just listen to what mechanic said. so, next service, will buy 1 and get it fitted. Is it standard thermostat for wira/satria right, doesnt matter 1.3, 1.5 or 1.6? I wana ask here first before consult the car sparepart shop, at least I go buy the thermostat with some knowledge. Mine is 1.6
The thermostat is there for a reason.....lol
the con of running without one is your car will take longer to warm up...
My previous 3rd car was running without one, not to say longer to warm up, but actually hard to warm up and if rain really cold......lol
lsm1991
1,469
185
ahh oil cooler without its own thermostat, same issue, takes forever to warm up in the rain
jebatdex
430
18
Skudai, Johor
but if i go to spare part shop, asking for satria thermostat, it will be the same right all wira/satria model?
in case some model big size or small size, the same case with oil filter.
Thermostat should be one size, but Proton oil filter actually have big and small......lol
Nothing that I am aware of.. i think the car has travelled around 5000km without thermostat until now.
it'll be a slow and painful death. Piston rings, valve guides, cylinder walls, etc. Unless the fella runs really really good oil la. Then it'll be a very very long but eventual painful death
parakey
1,367
226
Not unless he's the sort who warms up his engine slowly .. like 10 minutes before each drive
Not really. There are those who use thick oil like 20W50 or which kinda isn't that great when cold. Even the warming up process still starts off when cold so the quicker the oil reaches operating temp the better it is overall. If it takes longer the wear is still there even if the car is stationary.
alcyon
800
153
543
ok yes... im also thinking to do top overhaul soon, seems have some oil leaking at the distributor area.
Distributor o ring enaf dee. If you are handy , you can change the thermostat yourself. Back in my proton saga days I was experimenting with drilled standard thermostat and SARD racing thermostat. I opened up the thermostat housing repeatedly and put it back lol..
Reactions: parakey
jebatdex
430
18
Skudai, Johor
not just that, some white smoke also coming out now. haven't check the oil reduce or not, will check when engine is cold this weekend morning. i suspect some reduction.
Hey guys, as you all know there are the new MF car batts in the market now.
First some info for all ZTH bros before we go on, when you buy MF batts, pick the Expanded Metal types. Batts like Century MF are not Expanded Metal and are from Thailand, hehe. There's a difference but it gets really hard to explain, maybe in my next post when i have the time.
And even better, we should support local made products so buy ABI MF batts, those are made in Malaysia. GP MF Batts are made in...
