myvi brake system
likemise
11
2
503
Johor Bahru
1.5 calipers are now 400 bucks each.
Anyway I ordered AR racing 16mm version rotors and steel braided hoses.
Pads I am planning to use sumitomo.
30,002
Sumitomo what grade? Is not the brand, every brand have their category like entry level, semi metallic or ceramic then a high temperature pad too. Get the ones that suits your priorities....:driver:
minibeany
599
102
543
You never said whether yours is the 1.3 or 1.5? If 1.3 swapping to the 1.5 Myvi calipers and rotors. it's plug and play for the 1.3. It's a big improvement for the 1.3/1.0.
If yours is the 1.5 then you'll need to find a customizer to custom make the bracket for any caliper you want to fit on. Wira 1.5 / GSR / Mivec one is cheap to buy and fit. Hondas are a bit more expensive but work great. 2-pot / 4-pot are overkill and expensive and will more likely force you to swap to bigger rims.
mine is 1.5. The mechanic recommended to change to Honda Odyssey with the condition rim has to be upgrade to 15 inch too else will not fit. is that true?
30,002
Are you modding your engine for more power, if not, why go for such big brakes? Might as well change to better pads....:driver:
mADmAN
1,840
547
just drove from jb to kl and back to jb last week with my stock tyres and brake pad. Was actually more manageable than I imagined.
errr...wat were u expecting? its just highway drive...so i really dont see any reason why it wont be manageable? somemore on highway u barely touch the brakes which means lesser occasions for it to overheat.... plus on highway air flow to the pads is rather constant...so....
i get the feeling that ur expectations are too high and ur opinion on stock stuff is too low...
yes true... and even then.... not all 15" can fit.. need to take wheel offset and and spoke design into account... 1 wheel that confirm will NOT fit is the Enkei RPF-1 15x7 +41. this is due to the spoke design.
and agree with vr2turbo. a simple brake pad upgrade is probably more than sufficient for most people.
Remember F1 Driver Robert Kubica? Well here’s a recap: The Polish driver was severely injured during a rally in Italy when one Robert Kubica crashed his Skoda Fabia S2000 into a guard-rail that impaled the car by breaching into the cabin via the front, consequently almost severing the Polish driver’s right arm.
<!--more-->With Kimi Raikkonen coming in from the rallying scene over...
