Lower arm bush
y2188
441
42
28
Actually he is correct.. Use OEM ones, especially Wira u can find Ralliart strengthened bushings or other brands. Its alot better.
However if u still wan to go PU, I suggest u r able to find those that 'melts' the PU or whatever material they use into the arm. I don't have a pic to show u but it looks like the bushing is bonded with the lower arm. These r more resilient cos is less movements.
PU Bushings like Lan uses is prone to deteriorating cos its loose in the bush center... there is free play (a little) and long time abrasion and vibration causes it to deteriorate.
And honestly... his skill is only so so.. the engineering is not precise. He makes his bushes abit looser (micro but enough to cause problems) and you think about it... if ur really that good y r u charging dirt cheap price? His target r ppl that superbudget and don't mind shoddy work. thats y u dont see high perf cars there. Im not looking down on under tree mechanics as my mechanic himself is under tree but the high perf cars u see there r alot. So skill matters.
The pictures above are from Lan Engineering work. See how the top and bottom rings already deteriorated. And is only 6 months of use.
Do you have any good engineering shop that can do PU bushing for recommendations?
mojo1ne
34
7
1,508
Initially we had the guy that does the PU melting technique but he moved somewhere dy and we don't know where. Haha.
Sent from my SM-N9208 using Tapatalk
sanekit
Dec 9, 2015
1,616
157
Fark. Now i scared looking at your photos. I'm on LAN's PU bush now for my wira lower arm. Already feels loose... Time to save up and buy superpro.. :bawling:
y2188
441
42
28
Aww damn. hahah. been looking for shops that can make relatively hard PU bushings , LAN one seems quite soft
kurt_629
872
54
johor
no, don't.
I have manage to find one that does this, located in Kajang if I got the name correctly.
I try to upload the picture when I got home
ixeo
4,788
3,080
KL, Malaysia
I can guarantee you SuperPro won't deteriorate. It is so hard and firm, I took it out.
The third generation of the Toyota Vios makes its official debut on October 19th and with this new generation, Toyota is making it a truly global model by selling it on every...
