What are you driving now?
RENESIS VIII
7,063
950
Ipoh
RENESIS VIII
7,063
950
Ipoh
RENESIS VIII
7,063
950
Ipoh
Normal to get sick ...lol...
In factory even worst in my case, cold hot, cold hot...hahaha
Sick already but still motivated enough to come post at ZTH. Sick started 2 days ago where I kept sneezing. Then yesterday feel like got fever, blocked nose, whole body aching. :banghead:
Why your factory so weird cold then hot? Going back and forth from air cond room to factory is it?
30,002
Thank you very much for the bump. :adore:
Or you guys can post more photos of your current car. :biggrin:
So, if only got one car, today post front end, tomorrow rear end, then left side, right side, top, 45 degree angle, left corner, right corner and so on......hhahhahahahah:rofl:
RENESIS VIII
7,063
950
Ipoh
Endless possibilities and combination of photographs. Sometimes maybe can include engine and interior shots too. :biggrin:
Smuldge
12
2
1,503
I go out quite often in Ipoh. :biggrin: Ipoh is a small place with few modded cars going around.
https://paultan.org/2005/11/16/proton-savvy-automated-manual-transmission/
Found some info. Seems like it is real semi-auto transmission with clutch, not torque converter.
Good handling is probably due to lighter weight? Your Perdana is heavier but when it comes to rear suspension, I think Perdana will have the advantage.
Sorry to bring out an old post.
But just to add, until now, Citreon is still releasing models using a Semi-Automatic gearbox and it has not been received well I think. U drive like a manual, then release the accelerator, push into the next gear, and accelerate again. Same as a manual but without the clutch. I guess downshifting would be the same but with braking. How to heel-toe ?
RENESIS VIII
7,063
950
Ipoh
Eh? I thought the ECU will automatically close the throttle during each gear change for semi automatic transmission instead of you releasing the throttle pedal yourself?
Since you are here, post something about your car. :biggrin:
Suzuki Swift Sport Zc31s
This is my first car, after graduated from college and enter working life was looking for a sub 100k hatchback with proper manual gearbox. There was limited choices as i wanted a brand new car. So i let with 2 choices either a Swift Sport or Satria Neo. If Honda bring in the CR-Z earlier maybe i would have go for it instead. Despite it needs Ron97 fuel to run, even happier if i feed her with Ron 100. this car never failed to put a smile on my face whenever i encounter twisted road and still until today making me use the longer route home. From end of last year Suzie has been retired as daily driver. Now it's my weekend and track day car.
Any specific issues or things that need to pay attention when buying this car now? Are parts still easy to get too? I'm seriously considering to buy this for my son to learn to drive, so any input is appreciated.
experts pls tell the ways of how to increase the pick up power for a kancil 660.
and pls tell how much it cost to do so.
