Honda CR-V 2008 problem
fazidk
413
5,183
Hi guys..will get straight to d point...this is d problem...temp gauge rises slightly when aircon is ON but back to normal when OFF..what cld be d problem? Pls take note that gauge in digital so to summarize it better normal operating temp is 2 bar below half...when 'prob' it rises 2-3 (3bars max so far)...AND it only happens when aircon is ON...when OFF its normal..
I've checked d radiator n spare tank...NO decrease in water...NO water drips stains on floor...aircon is 'normal' cold (x loss in coldness)...
Need advice/opinion/troubleshoot
Thanx in advance..rgds
Fazid
This happens in town driving or highway? Is air con fan running or running fast enough?
When air con is on, the condenser in front is the heat ex changer therefore will be hotter up front. If fan is not running or running fast enough the radiator gets hot because heat from condenser transfer to radiator....
fazidk
413
5,183
OH sorry bro forgot to mention...only when idle long time it happens...both fans moving (radiator n ac fan)...tho I'm x sure whether d ac fan running fast or x (seems ok to me)
Btw how to check or know whether d fan is running fast/normal or x??sorry bodoh sikit :)
In that case I suspect the fan, because idle time car not moving, therfore no cooling by car speed so all depends on the fans to cool. Off air con the condenser not hot so radiator not affected
fazidk
413
5,183
Hmmmmmm adoiiii mampush...koyak lg la my wallet!!! Anyway thanx guys..will get it checked out later...
fazidk
413
5,183
Got d problem fixed (I hope)...found out 2 problems which 'caused' this (according to the aircon felle)..
1. Was d fan itself..he had to flick it wiz d finger then it started moving...slowly
2. The sensor at d fan itself...
Replaced d whole set n so far so good...fan spinning fast now
I'll consider problem SOLVED...
Thanx guys
Thanx guys
Have to flick the blade for fan to move means fan konk already. Hope your problem settled.....hhahahha
i think my car fuel pump is spoilt
when i floor my car usually on 3rd gear around 5-5.5k rpm my car will suddenly stop accelerating (it just wont go,like fuel cut). does this problem comes from the fuel pump or other component.
if it is the fuel pump what fuel pump is recommended for b6t.looking for used one.currently on tight budget
im looking forward to mod my car to 200+bhp later on
can evo's fuel pump be fitted.
n is b6t fuel pump internal or external
currently my car is stock...
