Oh! then just check whether all are connected and also the hoses got any crack that can leak.What i mean is i would like to double check does all the vacuum hose connected correctly as recently after hard rev engine stall and dies, jz wanted to double confirm all hose connected r rite
Too high or too low? Last time my VR I set high or low no problems? V6TT more sensitive?your FPR setting not right.
As far as I know, for vacuum hoses, as long as there is no leak and all are connected will work. There is no right or wrong way to connect them. When I fitted something that needed the vacuum hose to connect to it, they usually tap the nearest one so that connection is neat.But mine is stock fpr, anyone kind enuf can take a picture show clear how those vacuum line runs around trottle body there?
Haha, then no point in fitting FPR for the V6TT as we are suppose to alter the fuel feed pressure, might as well use original.....vr2, not sure bout that as I never used FPR before but heard quite sensitive for v6tt, need the right setting.
