<PLS HELP>saga flx 1.3 (M)result after change exhaust system
Apr 19, 2013
hi guys, i need ur help here. before i change my exhaust system, my full tank is around 300km.
but after i changed my full exhaust system, my full tank is around 250km.
what should i do ? is it the distance between the bullets matter ? cz i saw it in the forum, they said they have all the distance measurement of all the setup :'(
here's my exhaust setup:
-421
-flexipipe
-9" bullet
-12" bullet
-1.6" piping
-s-flow inlet 2'', outlet 2.3"
hamtaro00
279
39
Ipoh
1 resonator, smaller s flow see how.
Last time thats my setup on my 1,5 wira manual.piping is ori diameter.s flow inlet 1.8 inch if not mistaken.outlet cant rmbr. My resonator is not those twist with gigi inside ya. But once i increase piping to 1.8 the fc drop but on higher speed its slightly better. So i pair it up with ori muffler n fc improve a little. Beside exhaust n air filter, my head is port n polished and bigger rottle body.
When did you change the exhaust? Sometimes the ECU takes time to adapt. Give it a day or two to re-adapt.
Driving style got change or not? With better smoother power probably your pedal down more. However bigger exhaust usually drinks more. Look at the LMST noisy exhaust Iswara. My friend complaint very thirsty so he exchange the whole exhaust system for the normal Iswara one and FC improved, but power is down....:biggrin:
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
-421
-flexipipe
-9" bullet
-12" bullet
-1.6" piping
So many bullet and why your piping 1.6inch one? stock is bigger. somewhere 1.7-1.8inch
You can just removed 1 of the bullet and remain 1 enough. For me I only have a midbox (oval type) then to muffler couple with my headers.
Audi are pushing ahead with plans for an A9 supersedan to challenge the big boys in the likes of the Porsche Panamera and Mercedes-Benz CLS. The A9 will be marketed as a flagship luxury four-door sports coupe based on the A8.
The interesting part about the A9 is that the platform it uses could very well be used to create the production Lamborghini Estoque as well, killing two birds with one really lightweight space frame stone.
The master plan at Audi was always to produce sibling...
