Upsizing brakes in Nissan Sylphy
How come?
The sensor detects the toothed pattern on the driveshaft right?
Nothing to do with whatever brake u installed.
Or,yours is different...
I'm not entirely sure what the problem is. I'm going to need to find some time this week to dismantle the whole jimbang thing.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
After Izso told me on Sunday morning I then figure out what he was trying to tell me after thinking. The bolt he is looking for is called a Banjo fitting. Refer to picture below. It is usually used on caliper and hydraulic fittings. The Banjo fitting comes with 2 cooper crush washer.
Izso, I have this website which sell these fittings and usually it's hard to find on Malaysia website. This company they do international shipping or you can try to go find those shop dealing in hydraulic. They might have them.
Banjo Bolts and Brake Hose Bolts
This is the list of local shops dealing in hydraulics.
http://panpages.my/categories/my10843-hose-couplings-fittings/listings
New problem.
ABS keeps triggering even when I'm not heavy braking. Any ideas how to resolve this? I've tried a few things already and it's annoying like hell.
yewly1990
156
28
Hi all.
I've sort of successfully transplanted a 4-pot Nissan caliper taken off a R32 Skyline into my Sylphy. The only problems I have now :
1. I can't find a decently priced service kit. Anyone have? RM300+ for rubber seals is unreasonable.
2. The brake oil bolt that locks the brake hose to the caliper for the Sylphy is too long. I had to use spacers and washers to lock it out and prevent leakage. After asking 2-3 spare parts shops they aren't sure if they'll be able to source a shorter but similar bolt. Does anyone know where I can find a shorter bolt that has the hole in the middle to allow brake fluid through, 0.25mm thread and shorter than 3/4 inch long?
Any feedback, help or offers to sell will be appreciated. But if you have something to sell please PM, don't advertise here.
Did you try go to mechanical shop and custom one bolt? When I upsizing brakes, my bolt are custom also.
New problem.
ABS triggers when wheels are locked, could means your brakes are biting too well....:hmmmm:
peterj
1,321
258
1,683
Kuching
check my previous abs thread mr.izso.... u might find clue from there... try check for abs ring damages..if abs no damage check for dirt stuck on sensors... did your abs check light on?
No light. I'll try checking the ring again this weekend. I've already cleaned the dirt so that's out of the equation.
Dirt not so easy get there, right? Tiggo already 4 years touch wood, no issues....:hmmmm:
peterj
1,321
258
1,683
Kuching
Normally what stick on it is the brake dust... and since sensors are magnet,if the dust gt metal,more easier to stick on
Everything cleaned, new brake pads, spray painted calipers and installed everything. Brakes work. But I got a few questions for people who've modified to 4 pot brakes :
- The rotors are bloody heavy. So much so it adds to the steering weight and has significantly slowed down my acceleration speed. How do you guys work around this? Carbon ceramic rotors? Hehehe.. dreaming.
- Do you have the initial caliper clamping noise, a soft "clunk" everything you lightly tap the brakes? I seem to have this noise. Anything to be concerned about? From my own observation it seems alright.
- What if I uprated my servo, how would this affect my brakes?
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
2 piece rotor for light weight and fast heat dispersing.
Thicker servo=stronger braking force which i always like esp in big heavy car.
The sensation of stopping a heavy car can be quite addictive.u can feel the weight of the car being handled by the brakes.
On the rotors.i would leave it unchange but fiddle with the engine to give out more power.
Or u can compare the cost of getting a lighter disc to the cost of increasing the engine torque and choose.
cant u just retain stock rotor and use custombracket for the 4pot caliper only??? (but the disc size and thickness should not too-far off from caliper choosen.....those A31 cefiro 4pot caliper size i think very close to silpi brake size???
Brother, most people mod engine then mod brake to stop that power. You suka suka mod big heavy brakes with no mod to engine sure heavy loh......faster cabut.....hhahhahahhahahahha:biggrin:
I didn't know Cefiro was 4-pot and if it is 4 pot, it's already way bigger than Sylphy brakes. My GSR brakes on my Wira are slightly bigger than Sylphy stock brakes. True story. Even the disc is exactly the same as my Wira one.
The Skyline rotor is waaaaaaaaaaaaaay bigger than stock.
The stock brakes really tak boleh la. I almost got into some emergency brake trouble because of the stock brakes which is why I want to uprate in the first place.
Engine modding on my car is not an easy task la. I don't know where to start.
Actually the right approach to mod is first prepare the car to be able to handle the extra power first (i.e. suspension & brakes), not adding the power first, especially for normal cars like ours. Coz often after upgrade power, drivers can get carried away with the extra power and ends up in accidents instead.
My Mark X stock brakes also damn lousy one, not even adequate for the standard car. :mad:
---------- Post added at 05:23 PM ---------- 6 hour anti-bump limit - Previous post was at 05:16 PM ----------
Much lighter forged rims?
Hi guys. Just want to share something with you out especially for those whose driving Proton Waja. Last CNY while on my way to JB i take a break at Seremban R&R for breakfast. Take a break around 15 minute.Then went back to car then start it up.Few second after that my engine suddenly die.Try to crank back but nothing.Its cranking well just wont start.I suspect battery flat out sing the night before I do some upgrading work for my ICE. Temporally disconnect all recently make connection and...
