Adjustable for myvi 07. Brand and quality review needed.
mhdalef
Jan 18, 2015
26
What is the best brand,affordable and good quality adjustable for myvi. I'm new with adjustable. So need to choose a good one base on your experience. Thanks.
Sent from my iPhone using Tapatalk
How much budget do you have?
The ones that have been in the market with little to no problems is Kayaba, BC Racing, HWL, AR Racing, Improve hyperflex 1 and 2 and probably one or two other obscure brands. I'm sure Ohlins probably makes suspension for the Passo which could easily fit the Myvi too.
ken yeang
6,617
1,327
To TS, what is your expected ride performance?
Hardcore? Sporty, firm? etc?
Always the case, first got budget limitation? If no, then what priorities on the ride, whether more to handling or more to comfort, then etc. etc....:driver:
es2611
951
175
More to comfort and handling.
there is no such thing of comfort + handling.
u have to choose on one side and i never come across adjustables which improves comfort.
comfort = stick to stock.
mhdalef
26
What is the best for handling?
yeehau86
Feb 10, 2007
2,856
2,425
best + affordable + comfort + handling
all these combinations don't exist, it is BEST that you need to choose one path or another :)
es2611
951
175
thats very subjective. some people like all out "racing-hardcore" spec on the street.
some just like a touch stiffer than stock. list goes on.
preference preference preference!
ken yeang
6,617
1,327
TS, to obtain better advice from fellow forrummers....please state your price range.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
if u want comfort+handling but not affordable = TITAN, can costs u up to rm3k, they will customize the suspension to your liking.
otherwise go for HWL.will be less than RM800.
Myvi? Handling? Pfffffffftt... :biggrin:
That car was never designed for handling. No matter how many bars you put or what adjustables you use, it'll never be good enough.
The Kayaba adjustables I've actually sat in a Myvi with this suspension and I found it to be quite decent in comfort and quite respectable for handling. But it's still not going to win GRA contests or out corner other cars.
How about you talk about what it is you really want to do with this car? Like out corner SUVs in corners? Or just be that little bit faster in corners? Or reduce squatting and nose diving when you accelerate and brake? Or just personal enjoyment? If it is the last option - then whatever you buy will suite you. Everything is better than stock in terms of handling.
GRAs have seen a lot of overturned Myvis because of overzealous turning/cornering. Ever since then, people have stopped using the Myvi for GRAs unless they are just there for the fun of it.
I've only ever seen one serious Myvi on Sepang with a Toda 4AGE engine in it with full race chassis and all.
Anyway, I'm digressing - my suggestion to you is buy whatever you think is good that suites your budget. Because ultimately it's going to make you happy since it'll be better than stock but be prepared to lose comfort.
Or are you looking to stock up on all the Ultra Racing bars? If so, you can most definitely try. That might suite your requirements too.
Anyway, happy shopping.
Guys, To those whom had DIY their own vertical door but do not have good, strong or longer lift absorber to lift up the door, by all means...pm me, thanx.
