Suspension taller on one side & d.i.y
Andrew Philip
From Facebook
May 21, 2012
Shah Alam
www.facebook.com
Hi guys!
I noticed that my car (iswara. yes bear with me.) is taller on one side. I'm referring to the front suspension where in this case, the passenger left side is taller than driver's right side. I checked the absorbers for leaks and i found none. what could be the reason? Also, I'm curious to know where should i place the floor jack (i have a 2 tonne floor jack) when jacking up the car? I want to place the car on jack stands. I lost the car owner's manual and googling for the answers leads me nowhere. Hope you sifus can help a brother out ^_^. I'm still new to the whole d.i.y thing. Cheers!:driver:
ixeo
4,788
3,080
KL, Malaysia
because you sit on the driver side until the spring sag already lor...
ixeo
4,788
3,080
KL, Malaysia
but the height difference is quite alot :/ i understand the sagging part but it can't be that much right?
wear and tear... you look at the driver seat and the passenger seat..does the driver seat cushion look older/feel softer than passenger seat?
that much..means how much.. how many difference in cm?
Was about to say the same thing, but should be slightly only.....:rolleyes:
---------- Post added at 02:14 PM ---------- 6 hour anti-bump limit - Previous post was at 02:13 PM ----------
Height difference by a lot, then probably the spring lost it's strength/tension. Also check your suspension top mounting....
ken yeang
6,617
1,327
wear and tear...After all, it is a proton.
They dont make car last forever.
Just change to a new set of OEM spring.
Until you give more info on the height differences, I don't think anyone can give you a definite answer.
As for jacking points : I don't know about your 2-ton jack, mine's the mechanic 3-ton one and I jack the front cross member there, right in the front, but this is caveat that you've never had any frontal collision damage. If you had, then jack the arm or some solid part of the chassis. At the side sills there's two notches in the front, the jack stands go between the notches.
Supra_Fanatics
20,673
3,998
1st Gen Saga still running strong wor :rofl:
Oh! forgot about the jacks. If his jack is like my 2 ton ones from Tesco, they can jack the car engine up, but the plastics wheels will open up like track car negative camber. That is why I prefer to jack one side at a time, meaning one wheel at a time. The rears probably okay but not the engine or is it my VR engine is heavier?.....:hmmmm:
ye engine's weight remain the same.
u r getting older,no tice that u cant bongkok under the hood as long as usual?
i jack at the tow hook
jackstand at the front on the area whichbi believe is the chassis.for short job just place the stand on the front subframe.
on the rear,at the lower arm mountingnpoint to the body.
Under hood still okay, under the car then cannot ......hahhahahahah:biggrin:
C99D-MMC5537
287
78
Have u recently replacing the absorber top mounting rubber at only 1 side (Normally on higher side)?
DanzEterna
15,910
3,371
www.primeperdanaclub.com
your engine block is cast iron so should be heavier kua....can withstand high boost, unlike evos using alluminium block.
Yup, I think engine of VR is heavy. Today jack my Hyundai from engine center to lift whole front is no problem....:driver:
Today was adjusting the rear suspension of my Hyundai (adjustable) so measure the front too (non adjustable), the driver side also lower by 1/2 an inch....:smokin:
scoupe
1,087
37
5,148
shah alam
by jacking the engine you are stressing the engine mounts and in the oilsump( referring to engine center) there are points u can use to jack, towhook, subframe at the reinforced points as well as the reinforced points on the side of the car. happy d.i.y ing:)
Yah! not directly on the engine. Engine anyway is further higher up. Center of engine compartment to be more precise and that is on the sub frame....
Similar threads   Forum
Similar Threads
nicer interior and rear passenger head space problem resolve. Looks like Proton start listening. Hope that other QC problem got improvement.
