HELP: My Nissan Murano could not start.
poji_kun
108
Hi there!
I own an nissan murano, 2.5L, 2006 model.
Last week, my car couldn't start. Some mechanics said there were some water ingress and gasket bocor such. Had to overhaul engine and etc.
Before i spend my money, i'd like to get a second opinion from your truated mechanic.
1) hope you don't mind sharing your mechanics number.
2) do you know any good reliable workshop in KL?
Thank you.
ettm_14
605
81
hi, how many mechanics have you went to for advice?
what happen prior to not be able to start? did you over rev your engine?
just need more information so we can give some advice
poji_kun
108
I was driving from terengganu to KL. The next day, my Air cond doesnt't work. Sent for repair just some minor leaks on the pipes and the valve was stucked.
A day after that, i couldn't start the car. No signs of overheating or anything.
However, a week before, i did feel some 'knocking' in the engine at low speed. It was ok after speed above 40-50 km/hr. Not sure if this is an issue or not.
---------- Post added at 08:39 PM ---------- 6 hour anti-bump limit - Previous post was at 08:36 PM ----------
Btw, i went to just 1 workahop in serdang.
I now hv the car towed back to my house while looking for a better mechanic.
Nope. New battery. Just changed last month.
When you say it cannot start - there's no cranking at all? Or it cranks but won't ignite? Do you hear the fuel pump engaging when in "ACC"? Need more descriptive answers to do guess work.
Gamabuchi
Jul 20, 2011
39
12
508
However, a week before, i did feel some 'knocking' in the engine at low speed. It was ok after speed above 40-50 km/hr. Not sure if this is an issue or not..
feel or hear? if you can feel it then it is beyond serious already.
piston ring worn out, no pressure. piston moves freely inside, thus the knocking can be felt inside the cabin.. Overhaul is the only way then.
just my rm0.02
Supra_Fanatics
20,673
3,998
Check if your headlights are working, radio, room lamp. If it is working then battery should be fine.
open radiator cap..open oil filler cap and see if u can see this..
if yes.....then no other way...overhaul is the only solution
poji_kun
108
I want to cryyyyyy
Sent to a good mechanic. Issue was:-
1) crank sensor rosak. Easy replacement and not so expensive. The car now start.
2) my lube oil looks exactly like that!! The gasket bocor already. No choice but to overhaul.
I want to cry. There goes my savings... He he!
---------- Post added at 09:53 PM ---------- 6 hour anti-bump limit - Previous post was at 09:53 PM ----------
Thanks for the input, guys!
to all the taikors
how do we know when to change our car clutch palate?
Pls advice
