Project Holly - a live tale of my 1996 E36 M3 Evo
enthused
57
53
Quick clarification (pun not intended!) about sanding down the first layer of the clearcoat.
What was done was:
1) primer, sand, putty, sand, primer,sand, primer
2) Estoril Blue was painted on
3) Estoril Blue left to cure for 4 hours
4) HBBody HS clear sprayed on
5) HBBody clear left to cure for 8 hours
6) Sand flat with 1500 grit
7) Sand flatter with 2000 grit
8) Prepsol
9) Spray on Glasurit 447 clear
10) Glasurit clear left to cure for 8 hours
Thanks for reading.
leonl
229
81
USA
Beautiful color. Estoril blue is one of my favorite on E36. Years ago a friend bought a brand new E36 white interior & interior with vader seats. Another friend missed out on an original Lightweight M3, white with checker flag (It is worth a lot of money now). I missed out on an E30 M3 few years ago (Still regret it).
It does make a different with what weigth of oil you are running for performance & logevity of engine.
Thinner oil does gain a little of performance. Thicker oil will get a little more wear protection. Just like anything else, there are limitations. Too thin or too thick are not good. Imagine swimming in a pool of mud vs water. Many race motor uses thinner oil to gain performance but the engine will be rebuild after every race. As for most of us, we choose longevity.
Agreed, but I was talking about the first weight number. Actually I'm a little confused on your point. Are you advocating 0W / 5W/ 10W weights or not? Cuz I'm a hardcore support of 0 and 5 weight.
---------- Post added at 11:46 PM ---------- 6 hour anti-bump limit - Previous post was at 11:45 PM ----------
Btw TLG : Wth man.. I'm surprised you managed to even find a guy to go do that much for you in the first place. 99% of the people I know wouldn't even accept a job like yours much less do what you've asked them to do! This job probably costs well into the 5 figure price range?
enthused
57
53
Estoril Blue just works for an E36. It looks quite right with the somewhat boxy shape.
Veryyy jelez with u driving e36 m3 huhu
Thanks! Good to hear the hard work is appreciated :)
---------- Post added at 11:54 PM ---------- 6 hour anti-bump limit - Previous post was at 11:47 PM ----------
I completely understand... I too am an advocate of thin oils where they are able to keep oil pressure and don't cause engine wear. The startup protection and the ease they get up to temperature and give good fuel economy are key benefits to me.
Re the paint job - its not that expensive. I genuinely appreciate the guys at Veng Cheong. They took on the challenge and completed the job.
leonl
229
81
USA
You are right. I was thinking back and forth on the lower and upper weight & viscosity. Sorry about the confusion. Here is the link that explain better. Hoep that helps everyone. :biggrin:
Motor Oil Viscosity Grades Explained in Layman's Terms
enthused
57
53
Then, after a day of sitting in the paint booth drying, I finally saw it out in the open!
This is a completely unpolished and unbuffed photo showing the depth of the clear...
Then we do some polishing, and can see the shine starts to emerge:
You can see that no matter what you do, 447 scratch resistant clearcoat still doesn't have the same level of clarity as a good high-solid clear...
On the show goes with reassembly.
While CKIzso is AR in some areas - this shot shows you I too have some of that attention to detail -check out my new foglights, and all new metal clips securing the brake ducts and undertrays.
And so, 10 days of reassembly later we are here!
Thanks for reading!
leonl
229
81
USA
Very nice. Looks almost done. Congrats.
enthused
57
53
Could I ask you to PM me the price of this paint job?
PM incoming.
Thanks Leon!
---------- Post added at 11:40 PM ---------- 6 hour anti-bump limit - Previous post was at 11:00 PM ----------
At this stage of reassembly the pressure is really on. The challenge is there to get everything perfect and some things just arent in your favour.
The first challenge was in the central locking. When I collected the car this was already intermittent for the passenger door. As it turns out during disassembly we discovered some modifications to the central locking system. The gun on the drivers door had been changed for an aftermarket unit, whilst the passenger one was the original unit. This frustrated me - as when I made reference online to some PDF manuals describing the central locking system I realised that the logic would be compromised if this were done and deadlock facility would not actuate.
The deadlock facility is designed such that if the car is locked, even if the window is smashed and you tried to unlock the car from the inside it would not be possible easily, unless either the central locking remote was triggered, or the key was used physically. I wanted this back...
Another thing which was annoying was that the replacement of the door actuator for a coupe requires the removal of the window glass to gain access. Therefore putting the car back together was stuck. Under the pressure of time the frustrations of being a fan of an old car kicked in. The actuators were not available new from my usual source. The chop shops said they had them, but when I went to collect them said they weren't available... Two days of hunting later and having lunch with some good friends they were able to help me out and I was sorted. The actuators were delivered, and after some head scratching with rejoining the previously modified wiring we were back on track. Wherever needed we soldered and used shrinkwrap on the connections so they would be as good as original, and more importantly, would not oxidise or corrode as they are potentially exposed to the elements being inside the door where water drains into when it rains.
some shots of the excellent documentation online for the central locking system:
The next battle was for the front kidney grills. Being an early 3.2 EVO, the car has a pre-facelift nose. Many people said that since I had gone to the extent of a full complete respray I should take on the small additional step and facelift the car with the facelifted e36 nose. I am a stickler for originality so I decided against this. For reference, an image I found online which shows the facelift vs non-facelift easily:
The old grills were crispy black plastic which were glued together using 255 windscreen silicone. I wanted replacement originals but again no originals were to be found... The car (for shame!) currently has some cheap taiwanese copies whilst I find some original ones as the pre-facelift parts are getting rare...
Around this time I also got somewhat excited because it meant some of the finer items I had been keeping would finally be closer to installation - original stickers for the engine bay and door jambs and fuel lid which had been removed during the respray!
Thanks for reading!
I knew you were a stickler about originality. LOL!
And cool deadlock feature. I didn't know such a feature existed in any car! Wiras have it easy though, we just shave off the lock stick thingy so it can't be yanked up, have security plates so it can't be jimmied, then hide the door open switch. But then again it kinda turns my car into a trap for my passengers. LOL
enthused
57
53
Most of the european cars have it. The actuators weren't prohibitively expensive. They run about 40usd - while this is not really in the same league of a RM30 set of china actuators from mudah I couldn't see the logic in not taking the effort to fix the central locking properly as per factory whilst we were in there and the glass was all out.
Original interior stickers are cool as hell! :adore:
Thanks - they make me smile everytime I look at them! Its also this that drew me to the BMW as a platform for a restoration project, as stuff like this still exists! The only other platform which has cool restoration stuff like this is the Volkswagen Beetle/Combi stuff...
leonl
229
81
USA
Very nice details. I am really glad you choose the pre-facelift. I like the pre-facelift also. It is almost there, think about driving & enjoy it when it is all done. Especially done right.
Dear all sifu,....
i had few question to ask...
My project are bot on turbo to 4g93 sohc engine...
I had whole set turbo kit wif 390cc...
And it was low compression piston already...
My question are....
Can my original 4g93 sohc ecu and air fuel change to 4g63 ecu and air fuel?
Witout change wiring... I mean juz plug and play ecu and air fuel...
Or changing it to gsr ecu and air fuel... Witouut wiring?
Coz i dunwan buy piggyback...
Beside...i can get ecu and airfuel...
