NHC not stable crusing above 110km/h
aaronC
Seremban
Hi forumers, me and my family just got our first brand new honda city E+ a week ago, most of the time we are running around town and when we started our first long journey back to our kampung using north south express highway, that is when I felt the car reaction is weird occasionally going sideways when driving above 110 km/h even my wife and kid sitting behind felt that too.
So, I was hoping to get some inputs from you sifus to counter this problem by doing my first priority modification which is stability of the car. Please advise on the option below which is best suited. BTW the car has no body kit and is running on standard wheels 185/55R16 which i think is the problem.
Option 1 - Front top and bottom anti roll bar
Option 2 - Add body kit for aerodynamic
Option 3 - change the wheels to 195/55R15 or 205/45R17
Option 4 - change springs or adjustable coilovers
Any suggestion are most welcome :driver: Thanks !
Bro, there is not top anti- roll bar. There is top strut bar.
And I think there is nothing to do with the tyres. Try not to experiment with different tyre sizes until you are ready for any surprises in fuel economy and power delivery.
it might be but this happens through out my journey from kl to seremban whenever i step above 110km/h
any chance that we can counter the cross wind??
Go back to honda check alignment dont go outside tyre shop unless you know them well
Thanks for the advise guys, my first service will bring back to honda and check while in the meantime planning to install the top struct bar and the bottom anti roll bar and see how it feels overall.
don't modify things unless u're ok to give up warranty..
Going sideways at certain stretches? Could be cross wind?
Agreed with bro vr2, when the platform is flat enough, the wind chamber is incredible some car even moved automaticlly to the other lane during midnight cause the wind is stronger..
Bro, those chassis bars are good to increase stability especially for cornering. Also adds to safety. But they will not solve the problem that you are having. Anti-roll bars resist body roll while cornering. The tradeoff is that you will lose some independence between left and right and will lead to some jarring (side to side movements) on uneven roads.
To me, your problem sounds like alignment, steering cushion, rack end, uneven tyres (bumps) or cross wind. That is just according to what I experienced before. To make sure, best check with honda.
Agree with this especially since it's still a brand new car.
Option 1 & 4 will improve your handling a lot but might revoke your warranty. Btw top bar is strut bar, not anti roll bar. I suggest if want to add/replace, better go with front & rear anti roll bar instead of strut bar cause those 2 give the most benefits, along with sport suspension.
Option 2 will not do anything, just cosmetic only! Those body kits are not designed by race teams to add down force so don't expect much.
Option 3, will also improve your stability and may not revoke your warranty but might be the most costly. If still want to change then I'd suggest to still stay with 16' rims but get wider 7 inch ones so that you can fit 205/50/16 tires. Choose the lightest rims you can afford and stay away from heavy ones as it will be detrimental to just about any aspect of your performance (acceleration, braking distance, fuel economy).
Check the suspension too, you never know have faulty ones even new...:rolleyes:
---------- Post added at 08:24 AM ---------- 6 hour anti-bump limit - Previous post was at 08:19 AM ----------
Yup, agree with Option 2, the body kits more for looks....
Option 3, TS mentioned 195/55R15, don't go smaller. If typo and means 195/55R16, don't go higher too.
Bro. Guest suggestion of 205/50R16 is correct size but need to get wider rims. The OE ones should be too narrow, but with 205 width, the car may struggle with power.
Dear guys, i have check the tires pressure, suspension stiffness, allignment of the car and everything seems to be fine, anyway first service is coming soon and will check with honda, lets see what the honda mechanic says and will update here again.
btw, me and my wife decided for option 3 for our first mod and the next mod will be option 4 for aftermarket springs
p.s. she prefer the looks of the car with wheels first :) hmmm time to spend some time googling some 16'' wheels
yeah, and I hope it does not void the warranty for changing the wheels, need to check with honda.
Thanks vr2turbo, Veloc, neohadri, desmond0318, 6UE5t and pandaB for the advice and tips.
Bro, any recomendation for a good place to get a set of nice wheels ?
saw this on the net, very niceee
according to tyre shop, most faith branded rim r made in china now aday, it will easily crack....
as me, i 'll buy advanti, lenso.....or ......japan oem rim.....safety purpose.
If you really want to change to lower sport springs, it's better if you do that first before changing rims so that when choosing rims & tires you can really see the resulting clearance and how the stance looks. But if you're really undecided on the springs, then just make sure you buy rims and tires which stays within your fenders with plenty of clearance when doing full turns, and about the same total diameter with the std, so to minimize the risk later when your lower the car it won't scrape the fenders or inner sides.
Agree, better buy well known brands even if made in Taiwan/Philipine like Advanti, Lenso, Enkei (non Japan). Those are good value for money if you cannot afford Japan/Euro rims. Remember to buy the lightest one you can afford, don't just focus on the looks.
Klang, Rawang but you are in Seremban?:smokin:
And what tyre sizes you going for?
Current standard wheels are on 185/55R16 and considering changing to 205/55R16
Thanks for the tips.
I'm looking considering for Enkei RPF1 and SSR type C 16" 7jj ET42 or 43, among these 2 rims which are the lighter one?? and when you mean light how light is light ??
---------- Post added at 07:21 PM ---------- 6 hour anti-bump limit - Previous post was at 07:11 PM ----------
Yup, I love to drive and don't mind travelling for good stuff and especially good food :driver: Klang has cun Bak kut teh there
as recommended 205/55/R16 to maintain back the diameter of the stock setup in the mean time has a wider surface on the tarmac, and I hopes this will improve when cruising above 110km/h
---------- Post added at 07:23 PM ---------- 6 hour anti-bump limit - Previous post was at 07:21 PM ----------
I'm sux at multi quote....:itsme:
Both those wheels are very nice already. RPF1 should be a bit cheaper than the SSR but the SSR is a bit lighter if I'm not mistaken.
Well, light Japanese rims can be only 5-6kg or even less per wheel for 16x7' size. For your comparison, my 17x7.5 Japan rim only weigh 6.5kg, so a good 16' Japan rims would be 1kg lighter than my 17'.
You should use 205/50/16 if want to maintain the same diameter, not 205/55/16. 205/55/16 will be too big over 2cm already.
Bro. Guest is correct. From 185/55R16 the correct size is 205/50R16 and not 205/55R16. Overall diameter increased too much and over 3% rule. 3.61% to be exact.
205/50R16 is almost exact fit and with 7J, just nice....:driver:
Thanks for the advise guys, thats the size i'm going for and I found a place to get the rims at
Sport rim ORI SSR Type C Made In Japan 16 inci - Car Accessories & Parts for sale Selangor - Mudah.my
these SSR type-C weight only 5kg :driver: and i'm looking to wrap with michelin ps3.
Guys, where do you get your rims from ?
A thread every 60 seconds
