lighten crank pulley for myvi
dillon24
Apr 1, 2013
21
503
dear ZTH sifu's
does light crank pulley good for myvi?
1. in terms of pickup
2. advantage and disadvantages
I'm currently driving myvi 1.3 auto.
thanks! :wavey::biggrin:
No disadvantages and you get a faster moving rev counter. May or may not translate into faster acceleration.
the rumors that when you use light crank pulley the car hard to go up hill. I just read it somewhere. lol.
It'll affect only if it's undersized. I had no problems running around with my Myth pulley and my current car has no problems with the Mythelogy pulley as well going up and down Genting Sempah.
jun_ng_1208
476
32
Cheras
If its an undersized lighten pulley, the top speed of the car would be affected as there is not enough momentum on the pulley's rotation :) but there isn't such problem on a OEM sized lighten pulley ;) I used both of it before :D
ixeo
4,788
3,080
KL, Malaysia
Words of wisdom from someone who used it. Don't waste your money.
And time.
But mostly don't waste your money.
Veloc
3,234
991
Sabah
If you're talking about local brands, Mythelogy. They have reinforced center steel sleeves and the controversial harmonic dampeners.
I second this. The dampener is crucial. One of the defining factor to the lifespan of your engine. Use a dampened one, or if you cannot find one, don't bother changing.
Nov 10, 2016
4
If its an undersized lighten pulley, the top speed of the car would be affected as there is not enough momentum on the pulley's rotation :) but there isn't such problem on a OEM sized lighten pulley ;) I used both of it before :D[/QUOTE
where can i buy this/.and which workshop can adjust that pulley perfectly
Just done DIY Install Stromberg for my Charade Aura. I bought 6 units of Stromberg from Zerotohundred fellow nick name GTR a.k.a Ron. But since my V6 is at the workshop for upgrading my brake system so I decided to install these units into my Charade Aura first.
Later on I consult with Ron about this project. He said that my Charade should use only one big unit of Stromberg only:confused_smile: . He said that my car will jerking like Kancil. So I decided to test drive and found out...
