Hyundai Atos 1.1 M 03-04
Supra_Fanatics
20,685
3,998
no la no time...i reached there almost 2. was in a rush cos dowan to join the jam later.....
summore brought my family so cannot lepak....
atos prima still expensive, my budget less than rm7k.
atos 1st model, round light 1.0 manual. 02-03 if not mistaken. dowan so many owners la..
tq bro.
Haha! K noted, will let u know
budakkampungaje
317
Dengkil
neo. kenari still expensive, if the price similar to atos i will take edi.
cos my budget less than rm7k.
bdkkpg. if for me i take charade aura gtti edi...but wife wants a stock std car...
preferably mini mpv.
Dont take gtti jusat take kissa and g200
zeuz
250
14
3,018
Common fren ive done alot of hyundai convertion frm malaysia to singapore n also i have atoswit 1.3cc
Who said fc are bad n part are so hard to find....seek knowleadge at facebook hypermalaysia there u can see commity of hyundai harcore modder n stock player n find some true answer....pls don judge book by it cover
DanzEterna
15,910
3,371
www.primeperdanaclub.com
still looking for an atos....below rm7k....anyone can recommend?
bdkkpg....picanto still expensive, if my budget more than rm10k will definately go for kenari.
budakkampungaje
317
Dengkil
Then go for atos but find manual trans.....
Sent from my GT-P6200 using Xparent Red Tapatalk 2
zeuz
250
14
3,018
Atos 1.0 much easy to find part rather then 1.1 atos coz 1.1 is actually picanto engine. ....if 1.0 u can share eit suzuki solio part example gbox intake n internal part. ....i hv atos 660 turbo from korea
DanzEterna
15,910
3,371
1.1 really that hard to find ah? even airfilter take 1 day to arrive, dunno the spare part shop run out of stock
or need to order.
just wondering, how much the labour costs to change spark plugs & timing belt?
DanzEterna
15,910
3,371
few days ago my car cant start...had the tak tak tak sound, usually its the battery at fault,
so bought new batt & hoping can start as usual...it did....but the next morning same thing. next day
went to bought starter (recond), got it fixed & it started like normal.
then when reach home tried to start again the problem occured.....so brought back to mechanic
tested here & there, then finally told me that my grounding was not enuf....so i went to search for an earth cable at my usual spare part shop, he does not have it, he told me to get it from accs shop, surveyed & it costs rm180 for hks purple color, damn bloody expensive.
later on went to my previous supplier that was nearby my hse as he previously sold it for rm9 only. but found out he already closed down.
i gave up & returned to my workshop & told my mech to just make his own grounding cable, he did it & the car started like normal again.
costs incurred.
new ns40 batt RM90
recond starter RM90
workmanship to replace starter RM60.
DIY grounding cable FREE..
i was wondering, could it be just the grounding cable at fault in the beginning? if could have saved rm240.hmmm...
ronaldindin
207
29
www.12bet.com
costs incurred.
new ns40 batt RM90
recond starter RM90
could be. If battery faulty then you wouldn't hear tak tak sound in the beginning, pros please enlighten about this issue.
Btw RM90 for NS40 battery is fairly cheap. what brand you go for?
DanzEterna
15,910
3,371
normally if tak tak tak sound in the beginning the 1st thing in my mind is that the batt is weak as i just gotten the car & never knew when the previous owner changed the batt.
the brand was HIROSHIMA. bought from spare part shop with 1 year warranty 1 to 1 exchange if any problem.
but had 2nd thoughts that i had a weak batt as the headlamp did not dimm & radio works fine.
zeuz
250
14
3,018
Lan call me i tel u wat to do that ting is only cost u rm 10 seriously ctc 01116381005 can sms oso free jer no charge on u juz wan to help......tht is not a grounding trust mee i gv u 1 month or 3 wek the problem will come back if its cone back the its sure not grounding...i sudah kena before n sone other member oso kena before tis metter it is actuallt on our sensor if its tru that tis problem occur u ada lalu dalam hujan lebat....isit
DanzEterna
15,910
3,371
i had the timing belt & water pump changed yesterday & bought HKS grounding cable together, everything kau time, the car can start, my mechanic said that he added on a relay & so far can start la. let say it happens again, wat do i need to do? as u mentioned the sensor problem, how much it costs & which sensor?
anyways after the timing belt change, my car feels very sluggish, especially 2nd & 3rd gear, how come ah?
damage
GAIDO timing belt set rm120
water pump rm80
HKS grounding cable rm20
workmanship + relay rm200.
I'm sure many people already done this.
But here is how I did it.
Prepare the parts :- a 9V IC regulator. ***7809, 2 pcs of 100uF/16V e.capacitors, and a heatsink and pcb.
Then solder all the parts together. The IC pin when seen from front side is Input-Ground-Output. Connect the E.cap at input to ground and output to ground respectively.
Buy the ciggarete jack (since im not...
