Spoon Rigid Collars
PocketRocket
'(00) Mod'er
11,388
953
Up Yours
It will improve road handling and rigidity of your car, simply because the alignment between the subframe and body is corrected. Stiff Rings also has the similar effect and Race-Tech. You'd only wonder how magical these set of washers are until you fit them on and leave the workshop.
Supra_Fanatics
20,685
3,998
Nothing else for me to add. Totally Agree :top:
Supra_Fanatics
20,685
3,998
Spread poison pulak....ishhhh!!!!
How about chasis foam? works good?
Once a mech told me, ride is more quiet, and chassis stiffer or something.
BUT there were once some bad feedback from one of the forumers somewhere, cant remember which thread about foaming.
But then Stiff Rings, Rigid Collars are a good investment. No need service or maintenance.
Just get the workshop people to tighten all bolts during car service will do.
15,390
downside to foaming is if you get into an accident that hurts your chassis, your car is a write-off. It can't be repaired
Supra_Fanatics
20,685
3,998
Cuz the foam has already hardened and already being part of the chassis right?
So Cvkit, to be safe, put on stiff rings or rigid collars, whatever rings :biggrin:
Wedding rings if have to (Just kidding)
Cheaper for stiff rings, foaming is expensive.
Supra_Fanatics
20,685
3,998
Viva available but not too sure about CRV, don't remember seeing it but like madman mentioned, just log into their FB or just call them, I think they do custom made as well or some models are still in the midst of developing.
I waited like 3 months for my car model if not wrong, I just keep asking on FB :biggrin:
Supra_Fanatics
20,685
3,998
stiff ring is available for viva.
just installed it last 2 weeks at Speed Mod in cheras...good workmanship.
there is also discount at dat time.gud luck.. :rolleyes:
Did mine there too, quickly install once knowing there is New Year promo discount :biggrin:
A bit far but then, since stiffs rings are from them, so went there instead :biggrin:
My last weekend DIY project for my spectra.:biggrin: Heat shield with CAI for my Apexi . HS with Cover and CAI
My bonnet insulation DIY
Insulation
:biggrin:
