Racetech "Rigid collars" / Chassis Alignment Kit
Master Fuol
7
penang
Its people like you, buying all these copies that causes these companies to go bankrupt.
I can't believe your actually advertising copied products.
stevenseahkl
From Facebook
Sep 26, 2010
19
7
503
www.facebook.com
MASTER FUOL. If this is a copied product, which and where can we get the original? brandname and place of installtion plus price would help. Am interesting in trying this out
D7zul
2,697
848
Shah Alam
You know how much your words mean to me?
I myself is an enthusiast. Driving an AE111. I love the car for it's robustness, tuning potential and options. One will know if one watches initial D. But the limiting factor is $$$. Some people will always tell me no need to waste time because no matter what I do, it won't be an evo/skyline/FD beater. What I have been doing is do little little things like you, a bit at a time to make it much better than stock. That's what I can afford for the moment.
can't beat evo/skyline/FD???
who say?
Knowledge is Power..
Applied Knowledge is Using the Power..
and MONEY MAKES IT A REALITY..
Muahahahaha :evil:
WPQ800
1,445
92
1,648
true n not true both the same time.....
true
if let say u are buying hks mushroom filters...... then its very2 un-ethical to buy replica one cos it will spoil the original reputation of the original item
not true
if it is sumtin like this item here cos originally developed by spoon, bear in mind only for honda.... not for all.... so whats wrong if there are other manufacturer use the same theory/technology and develop it for other models since spoon doesnt develop to other brand except for honda?
FYI, a patent is only copyright protected for 5 years, after that it may be used generally.... if there is a change in the patent more than certain %, then it voids the original copyright terms.....
WPQ800
1,445
92
1,648
true
not true
FYI only, not to taruk ppl or tunjuk pandai..... jangan marah aaaaa....
romen_
188
49
kl
Highly agree on the car being more comfortable after that.. odd eh? LOL!
speed2horizon
2,798
334
1,683
Actually... If the guy up there read properly... The CAK is designed differently and uses different material compare to Rigidcolar. Same purpose, and different approach.
Rigid collar uses soft material Crush to fit. = 0 tolerence. 1 time usage.
CAK uses T6061 aerospace grade and install to minimize the tolerance.
Aduii.... BTW, does Honda, TOYOTA, Mitsubishi, Nissan, BMW, Ferrari etc etc got sued from Ford for using 4 tyres in their cars...?
Haha... Have a nice day bro...
I just read from the CAK manual. It also acts as an vibration isolator when it's being sandwich between the subframe and the chassis. Because, T6061 is still softer than steel
im juz curius
fitting in a 1.5 hydraulic clutch pump in a 1.6liter engine does it effect anything ?
its look almost the the same like the 1.6 hydraulic pump but smaller a bit ..
thanks !
