How to overcome weak low end/weak throttle response?
afiq opel
Jul 12, 2011
31
6
508
After doing some research, I understand that the sluggish feel (weak throttle response) of altezza is caused by the heavy dual mass flywheel which weighs about 12kg.
So I have been thinking for a while and I know the only solution to overcome this problem is by replacing the flywheel with an aftermarket flywheel.
May I know where can I get one for my car?
I dont think I can drive the car happily with the OEM flywheel.
-the lightest flywheel that I have ever known is by ORC which weighs about 5.4kg
Thank you in advance.
afiq opel
31
6
508
If i am not mistaken the oem flywheel is not machinable, but idk whether its true or not cos i read that on forums.
Greytezza
1,130
68
1,648
Truly Asia
Afig..u can contact William of Trial for a solution. We have order
through him for a few units of Toda flywheel for our car.
mokh
226
14
This is good.beside using TREC, lighten flywheel will be much help decreasing throtlle lag.
---------- Post added at 09:05 PM ---------- 6 hour anti-bump limit - Previous post was at 08:54 PM ----------
Toda flywheel for altezza cost 50000jpy ~ rm2100.
Tom
TIMETOATTACK
Jul 6, 2000
5,566
3,230
does the altezza run on drive-by-wire? if yes, would a throttle controller work well? I know some cars truly benefit from it especially automatics
afiq opel
31
6
508
Thanks for the info bro. The TREC, is it can be used in a manual car? I'm sorry for asking this, I have only saw auto cars with it.
---------- Post added at 09:28 PM ---------- 6 hour anti-bump limit - Previous post was at 09:22 PM ----------
yes exactly. the TREC is a good device to reduce throttle lag, but many of the altezza overseas have them DbW changed to DbC.
mokh
226
14
if u refer to this TREC;
it is compatible to manual altezza.
however the product was discontinued from 2008.
this product can work on both way; with or without pedal sensor.
for altezza it work by manipulating the acceleration signal from ECU. we dont have pedal sensor.
it have only 4 wires; 2 wires for power (IG and GND), the other 2 are for input and output for acceleration sensor as per diagram below;
Greytezza
1,130
68
1,648
Truly Asia
Afig..another option is to pair your aftermarket flywheel with a 4.5 Final drive..our bro Adrenaline_Rush did that combo in his tezza and very happy with the outcome.
cuscostrutbrace
987
62
3,028
Well i think the acceleration position sensor is suppose to be 'accelerator position sensor',that is equivalent to your pedal sensor,because altezza still used cable to operate the sensor located at the throttle body.
1JZtezza
371
42
A weak throttle response could be caused by a myriad of things(AFM,throttle body,fuel pump,injectors..etc; best to get a diagnostic on the engine health first.
A Post Every 5 Mins
wondering if there any car owners install any of the products from ultra racing (chasis tuning)??any differences or improvements of handling?? i just only install front strut bar 4 point and rear anti roll bar on my 03 kancil..havent't test and see the diff yet..
