Brake Rotor
tkew
99
4
1,508
Ori rotor selling for 1500 a set is very expensive top up a some can change to BBK.
Better look for other option or after market brand.
mADmAN
1,840
547
try brake sets from other cars...
the R32/R33 4pot brake set for front only can get around rm500... pads and rotors im sure easy to find for future replacement.. check in marketplace or mudah
WyNG
1,569
75
1,648
JBT Brake system 4 pot , for the pad need how much ?
0-650c around Rm 550 imported from japan, only rotor and calipers made in taiwan
mADmAN
1,840
547
of course not plug n play...u need to custom the mounting brackets which is easily done...
main issue is the brake hose.. if the kepala not the same then need to make custom hose... which also can be done by alot of places. check with ur workshops
the key thing here is not just upgrading.. fitting is a one time thing.. but being able to find replacement parts in the future is important.
G221
Over 10,000 RPM!
13,344
61
guys,
interested with dba Australia brake rotors? I'm a dealer.
DBA Lexus IS 250 Street Series Slotted Rotors -DBA2726 SL/SR (F) Front set RM1500
DBA Lexus IS 250 Street Series Slotted Rotors - DBA2727 SL/SR (R) Rear set RM1500
booking: RM300 per set. estimated time to arrive: 3months at least. Delivery: at your door step/your preferred workshop within Klang Valley.
Features Patented ‘Kangaroo Paw’ ventilation design available on most popular DBA Street Series Rotors.
Directional slotted design (Left-hand and right-hand disc rotors)
Gun-metal grey paint provides better corrosion protection
Rapidly expels friction gases
Provides even pad wear and assists in minimising glazing of pad surfaces
Minimises brake fade
Ideal for towing and heavy loads, where additional heat is usually generated
The slotting efficiently clears dust and debris, while creating better friction and a cleaner disc rotor
direct replacement, plug n play.
pm me for more details :driver:
ed78
353
29
guys,
DBA good stuff,
if group purchase what's the best price you can give us? minimum set?
G221
Over 10,000 RPM!
13,344
61
ed78,
group purchase would be RM1400 per set. minimum set is 3, RM250 deposit per set. :driver:
1JZtezza
371
42
best to match pads with the rotors...my 2 cents
FYI: minimum thickness of rotor is 26mm(apparently off some manual somewhere) DBA rotors thickness at 28mm.For comparison brembo and project mu rotors( using stock calipers) comes at 32mm. cheers...
G221
Over 10,000 RPM!
13,344
61
the price is already nice bro with free delivery service :driver:
---------- Post added at 04:48 PM ---------- 6 hour anti-bump limit - Previous post was at 04:41 PM ----------
yup, taikor 1JZtezza is right.
please refer here:
http://www.dba.com.au/products/dba2726sl
ixeo
4,788
3,080
KL, Malaysia
ed78,
that's an awesome price already for DBA. cause the best EBC prices i can get also not that far off.
EBC Ultimax Slotted Rotors = RM1,350
EBC Sport Rotors (Slotted+Dimpled) = RM1,500
minimum order 3 sets, MAX 3 weeks to arrive.
1JZtezza
371
42
look like no ppl interested in brake rotor .....no group buy no good price ... sad
hate to say this but just to remind you to go back to your original question/s
You havent even selected which brake rotor;size-diameter and thickness?
Bro's here recommended and introduced already....sorry if they dont hold your hand as their needs and preferences differ(brakes )
elephone
106
2
3,018
KL Cheras
Sorry about it, size for OEM and just see any others member need which one. I don't have any idea for this brake rotor
elephone
106
2
3,018
KL Cheras
Bro ed78 , u change back ori rotors ? where u change how much ? if cannot say pls PM me thanks .
Hey guys,
I'm new here...i need some help from the sifus here.
Anyone have install gearbox oil cooler to ur car ? How much would it be and where can i get one to fit in my CF4 ?
Thankz
