Stolen:satria gti JFH 120
my friend GTi just now when he went down to parking lot at around 8pm, notice all the ignition switch broken. only the secret lock the thief didn't manage to open. exactly like my putra kena last time. the thief also failed on the secret lock. so i told my friend to put this lock too 3years ago. just now he call me to thank. :)
Bro, what secret lock?
exactly man....whats a secret lock and do u have the secret recipe to unlock victoris's secret?
secret lock/switch/method
1)hidden fuel pump relay switch(even ignition key on,cannot start engine coz ,fuel pump still off if the hidden switch still not on/activated)
2)hidden 2nd ignition switch/starter relay(need 2 key too start the ignition,usually the wiring is by pass directly from the relay box and dies not use the wiring loom wiring,only if hidden key is on,the engine can be start via ignition key)
3)remove spark plug cable and keep in bag
4)remove ecu/not reccomended cause car will reset the idling,air fuel closed loop
is the satria door easy to open like wira from the window with rulers? if it is.. better do something coz its so easy to do it..tested on my wira few times and can be done less than a minute..
I would say method #1 & #2 are more practical. Just install these hidden switches by your trusted mechanics / accessories shop and make sure no one else know about it.
hehehe.. i also not sure either i should reveal the secret lock here or not. it's none of above forumer said. it using padlock. if u got much budget maybe can use high-end padlock like Abus or Abloy. i just use a normal sunso also OK for now. plan to upgrade. pm me, i'll reply u where to put it when i have time. as i know proton/mitsu can use this lock. others car not very sure.. :)
mechanical lock using pad lock?i like this one.nothing beats mechanical lock compare to electronic lock.
don't think the car jacker can gergaji it in confined spaces.but liquid nitrogen might do if the stealer can source it.
wahh sudah pakai liquid nitrogen ah like fast and furious 4 oni when they hijack the petrol tank :biggrin:
All those lock items are super safe, but just so you guys know, mine had almost all those security measures mentioned above but still got stolen. It was TOWED. Damn those thieves.
but in certain type of parking lot, towing is impossible. same like my friend n my case previously.. my friend tell me that his apartment security manage to get the thief photo via cctv. malay - male. around 20's. already submit the image to police station. now, he is selling his GTi already. hehehe.. who want GTi, let me know. UK spec. leather recaro seat. very2 nice condition.. below 30K. no loan. :biggrin:
