D16A Turbo EG8
e-jump
203
3,018
-The RB25 turbo is T3 flange. So, it's a plug n play.
-The turbo comes with internal wastegate. So, tial is optional.
-BOV, my friend and I have personally tried synapse imitation. As good as the the originals. And still holding strong at 35 psi.
-FMIC, JASMA or China ACR will do. Forget about the big big intercooler if u are looking for response -and torque. The GSR front side mount is good. Or, the Mitsubishi V6 Twin turbo is good and they both cost <RM300 complete wit piping. Just mod the piping.
-Boost controller is built in on the internal wastegate actuator. There's a screw to adjust. The aftermarket boost controller is to increase boost and not decrease.
-The non Vtec is as good as the Vtec rods.
-Injectors and fuel rail. Ur stock fuel rails are more than good for ur proposed application. regarding the injectors, u can opt for the Mitsubishi 4G93T injectors(390cc) which require a resistor pack u can purchase from Jalan Pasar. Just get the resistor for alternative current(long square white color) 10W 10ohm.
Hope this helps....
Again, thanks bro :adore:
These infos are super helpful.
I guess im somewhat on the right track. now i need to study more on whats more that i need other than emanage for EMS.
Also, do you have recommendation on who can help with tunings in PJ/Subang/Sunway area?
APTuning
Stock engine can make 300hp.without EMS your daily driving make you headache and engine overheat.D16 one of the small engine and strong sleave can hold the 500hp with proper tuning.
I hear many complaints here when using a turbo to D16 engine.When the boost in,heat will increase and the timing should be retard.EMS is important..
Good Luck
Advanced Performance Tuning: SOHC D16 350HP Factory Engine
e-jump
203
3,018
Thanks for the tips bro APTuning
in the expense of saving cost, its like i'm asking for trouble LOL for a DIY-turbo.
Now doing research on 'turbo module' thingie which i dont have a clear idea what it is.
Also i shall consider better radiator for cooling
speed2horizon
2,798
334
1,683
FPR is something nice to have, but not something necessary. Fuel pump, i think the oem is sufficient for ur application. U also need oil feed(normally take from head, T the pressure sensor) and return for the turbo. Water cool hoses(from main water pipe and return).
Customize downpipe.
Boost meter
---------- Post added at 12:07 PM ---------- 6 hour anti-bump limit - Previous post was at 11:53 AM ----------
E-damage... Oppsss I mean E-manage is actually sufficient for your application. My friend has been running a DIY set up without problem for over a year with no dramas until the car was stolen...
The guai lo boosted the D16 ZC with stock internals and head gasket to 375WHP. Only on ARP head studs...
e-jump
203
3,018
necroing a 4yr old thread.. haha..
reporting in that i have been boosted on my single cam (initially ZC) since late 2013.. its been 2 years already with lots of good n bad experience..
i went with a KLG BOT kit where everything is installed under 1 roof.
initial cost was around 9k+
what i got for that money
- FRP T28 spec journal w/ .49ar exhaust side.. Till today i never know the compressor ar
- big FMIC
- 510cc evo3 injector
- log style cast manifold
- 2.5 stock route exhaust, some big 3" tip mufler, open screamer pipe wastegate
- imitation Greddy typeRZ
- imitation tial 38
- 4pot s15 fronts, eg9 rears upgrade
- tune (i had emanage blue prior to boosting)
- 0.5bar boost
i made 180whp 23.~kgm tq boosting 0.5bar with stock clutch slipping on dyno lol.
i learnt alot from this project because from there i got to know my stock clutch cant keep up so replace with exedy stage2, and i need walbro 255.
and i have few points of where my engine broke due to
- original headgasket was carbon n it blown.. later upgraded to 1mm metal hg + ARP studs. engine salvageable.. just to do head work. around 5month after boosting.
- engine start consuming oil like 150ml a month. i had to move to heavier 20w-50 oil.
- improper install of sandwich plate after installing oil press/temp sensor causing oil starvation. this happens 1yr after the ARP studs upgrade. turbo broke as well
im still boosting to date with another D16A engine, but this time i dissect my engine, check all the internals, replace the bearings with ACL duraglides (originally bought for my ZC but have not installed), rebuild the turbo and use 1.5mm cometic mls gasket. unfortunately my arp studs doesnt fit on this engine so i run stock bolts.
My initial ZC(which was also a swapped as my old engine got destroyed from a shitty top overhaul job by another garage) when i did the BOT, i did not do compression test(in fact i never test it since i swapped it in). I do not know the history of the engine. But it lasted me few good years running NA.
My advice, if you want to boost your stock engine and you know your engine history, go for it but start safe from 0.3/0.4bar. at this boost lvl thick headgasket is not necessary yet if your engine is sohc vtec or D16 96 onwards as they came with oem metal gasket.
depending on tuner and luck, sometimes shit happens.. prepare for the worst.
good luck
/ps, i still have the ARP studs + 1mm metal gasket to whoever needs it (just drop me a pm).. but i recommend that if you have not pry open your head and have no intention to go high boost, stick with what you have (stock gasket + bolts)
Ok here is an idea. Electronic turbo...mild boost. Get a turbine and modify it to fit a 12v high speed brushless motor (seen some at 70000rpm at 50kW)....Drive the compressing blades into trottle body. Turn on only when you want. When turned off, some kinda sollenoid to change air flow around turbine. Meaning to say that from air filter 2 pipes split. 1 to turbine...and another joins back after turbine...so you routed the air manually.....interesting idea....not sure will work.
