- Joined
- Oct 14, 2008
- Messages
- 1,915
- Points
- 1,638
Item(s): XETEC Xircuit Xi-240.2 2-channel Amplifier (125W RMS x 2)
Package includes: 1 unit amplifier (Made in Germany)
Price: SOLD!! SOLD!!! SOLD!!!
Dealing method: COD (Damansara, Bandar Utama, Kelana Jaya, Subang Jaya....)
Location of seller: Damansara
Contact method/details: 012-21 363 07 (Avin)
Item(s) conditions: Absolute MINT Condition...Very Well Taken Care Off....
Picture: As Per Attached
Reason for sale: Upgrading...
Aluminum housing
HPAA technology
Highpass -, Lowpass and band-pass filter VCVS (= volume days control LED volume days SOURCE)
Filter for front and rear channels with bypass function
Balanced Cinch input for optimal freedom from interference
Entrance sensitivity 200 mVs - 6 V
Connection terminals gilded protective circuits against DC, overheating, short-circuit, overloading
Technical data
RMS output power @ 4 of ohm: 2 x 125 W
RMS output power @ 2 of ohm: 2 x 198 W
RMS output power @ 4 of ohm: 1 x 384 W in bridged mode
Max input Current (@13,8 V): 33 A
Idle current (NO signal): 1.1 A
Fuse: 2x20 A
Totally Harmonic Distortion (THD):<0,03 %
SNR: > 90 railway (A)
Freq.Response (bypass mode): 5 Hz-30.000 cycles per second (in bypass mode)
Damping Factor; 420
Stability: > 2 ohms, (> 4 ohms in bridged mode!)
Input Sensitivity: 200 mV-6 V
Crossover frequencies: highpass 25 Hz-6 kHz lowpass 50 Hz-6 kHz
Dimensions: 360 mm x 225 mm x 60 mm
![Smokin :smokin: :smokin:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/smokin.gif)
Aluminum housing
HPAA technology
Technical data
Fuse: 2x20 A
Damping Factor; 420
