maswaretools
Hi all. We are proud to introduce you a new range of Air Condition Gas Recycling Machine fully made by Luvata in Italy. The company has existed since 1580. For more information about the company, please visit Luvata Official Website
Business Futura
This is a semi-automatic service centre that performs operations of recovery/recycling, oil separation, air purge, leak testing, and oil and R134a coolant charge injection, in conditions of total safety. Easy to use and to move about even on uneven ground, Business Futura is a simple and reliable service centre, with excellent quality/price ratio.
Technical Data
- HP-LP ports, or only HP, or only LP
- Recovery: AUT
- Oil separator: AUT
- Refrigerant Recycling: AUT
- Oil draining: AUT
- Vacuum: AUT
- A/C plant leak test: AUT
- Oil & UV injection: EL/AUT
- A/C plant filling: AUT
- Automatic air purge
- Safety valve
- Electronic vacuum gauge
- Expansion valve
- Keyboard with big display 5 digit
- Refrigerant electronic scale
- 80 mm HP-LP manometers pulse free with calibration
- 50 mm refrigerant container manometer
- Oil containers with thread
- Long life hoses: 2500mm
- Vacuum pump: 100 L
- Final pressure: 0.05 bar
- Recovery power: 300 g/min
- Nominal pressure: 20 bar
- Double chamber distiller
- Double filter
- Volume of the internal container: 12.5 L
- Graphic printer with settable text & print: option.
- Steel chassis
- Window for oil pump Inspection
- Weight: 69 Kg
- Dimensions: 1172 x 618 x 525
- Power consumption in watt: 650
- Main voltage: 230 V 50/60 Hz
- Made in Italy
- Status : Brand New
Silver Futura Diag
This is an entirely automated service centre, with cutting-edge functions. Complete with diagnosis, software and database that can be updated by means of a proprietary memory card, and a graphic printer that can repeat the last service report, Silver Futura Diag also supplies the monthly gas in/out report, reflecting the company's great attention to market demands and new environmental regulations.
Technical Data
- Integrated auto data base
- A/C plant diagnosis
- Recovery: AUT
- Oil draining: AUT
- Vacuum: AUT
- Flushing (A/C plant cleaning)
- Safety valve
- Integrated soenoid valve manifold
- Expansion valve
- Alphanumeric keyboard with 4 lines display
- Oil electronic scales
- Dye electronic scale
- Oil containers with quick coupler
- Long life hoses: 3000mm
- Recovery power: 500 g/min
- Double filter
- Volume of the internal container: 27.2 L
- Steel chassis
- ABS panels high resistance
- Weight: 90 Kg
- Dimensions: 1220 x 630 x 625
- Power consumption in watt: 770
- Made in Italy
Tronic S Futura
This unit can be used for the automatic or manual implementation of all operations concerning recovery/recycling, oil separation, vacuum, leak tests, oil and UV injection, and recharging with R134a refrigerant. It can be completed with diagnosis and database (optional aftermarket). Precise and reliable, offering state-of-the-art technical systems at exceptional quality/price/performance parameters, Tronic S Futura meets the requirements of a demanding, high quality market sector.
Technical Data
- integrated auto data base: option.
- A/C plant diagnosis: option.
- Recovery: AUT
- Oil draining: AUT
- Vacuum: AUT
- Safety valve
- Expansion valve
- Alphanumeric keyboard with 2 lines display
-Vacuum pump: 100 L
- Final pressur: 0.05 bar
- Double filter
- Steel chassis
- Weight: 82 Kg
- Made in Italy
Live demo of the actual product can be arranged. We welcomed introducer to introduce our product to their customers / suppliers. In appreciation to their effort, we can make up some arrangement for their effort. We are also the appointed exclusive dealer for all government related supplies / contract by their sole distributor in Malaysia.
Maswaretools Online Store
http://www.maswaretools.com/
The online hardware shop
Visit our website for more tools & equipments available online!
Any inquiry please e-mail to [email protected]
Business Futura
Technical Data
- Recovery: AUT
- Oil draining: AUT
- Vacuum: AUT
- Safety valve
- Expansion valve
- Double filter
- Steel chassis
- Weight: 69 Kg
- Made in Italy
Silver Futura Diag
Technical Data
- Recovery: AUT
- Oil draining: AUT
- Vacuum: AUT
- Safety valve
- Expansion valve
- Double filter
- Steel chassis
- Weight: 90 Kg
- Made in Italy
Tronic S Futura
Technical Data
- Recovery: AUT
- Oil draining: AUT
- Vacuum: AUT
- Safety valve
- Expansion valve
-Vacuum pump: 100 L
- Double filter
- Steel chassis
- Weight: 82 Kg
- Made in Italy
