[wts] FULLY MODDED 1998 PERODUA KANCIL
spec-c
1,830
112
3,163
TTDi
Hello Folks
1998 Perodua Kancil fo sale.
Original : 850cc Automatic
Converted to: 660cc Turbo Manual (Endorsed)
Selling for RM14000nego
CALL 017-6033810
pics and mod list below
Engine: L2S (M) overhauled 2000km ago
Turbo TD04-09
SR20 Fuel Pump
Adjustable Fuel Regulator
240cc Injectors
Polished head port
External Wastegate 35mm
Metal gasket 1.5mm
Compression Hole
Gearbox Ratio 850cc + LSD + clutch bearing SKF..
Exedy 3 puck clutch (below 1000km)
Skimmed Flywheel
Apexi Afc 5 button
1G-GTE Intercooler front mounted, 1.7 inches
Battery relocated to the back.
Stainless steel exhaust 2 inches from front till back
Marco center bullet
HKS Super Dragger,
Cap Ayam Oil Catch Tank
Omori Boost Meter
Wideband tuned
Full L2S Exterior
Car painted maroon
HKS Blow Of Valve
ps- Aircon removed, will give new owner compressor etc to install again.
SYeNi69
402
47
TTDI KL
fuuuuhhhhhh ... FULLY MODDED ...
spec-c
1,830
112
3,163
TTDi
bum[p/////////////////////////
Bump: bum[p/////////////////////////
spec-c
1,830
112
3,163
TTDi
bymp..................
spec-c
1,830
112
3,163
TTDi
spec-c
1,830
112
3,163
TTDi
jual satu keta camtu je bro. sori xleh strip
let me start a thread
to all Brothers and Sisters
what we should upgrade for our engine and become a more power. U all can give ur solution or opinion of how to make a car faster with low budget or more expert modification. It is better we suggest for the NA engine, this is because turbo engine is too power already.... :tee:
Let me start for the 1st stage modification of the NA engine
1. ) Changing the ekzos system. (It will be cost u about 300-800) depend on the brand we choose...
