WTA: What engine can put in to proton juara????
bolok1111
38
sms me:012-6901834 need help.....
better all sifu help me.... i need 660-1.0 turbo engine that can
put in my pronton juara.......
who got do transplnt before?????
tq
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
actually i never see with my own eye how the juara engine look like...hehehe
care to share the pic of the engine?is renault engine compatible?
azlan609
91
proton juara similiar with mitsub ishi town box in japan.got turbo engine also got fulltime 4wd.but only 3 silinder and 660 displacement.
---------- Post added at 08:46 PM ---------- Previous post was at 08:45 PM ----------
pls survey at cars-directory.net for that model..
evorunner
19
1,503
don't know la..people only do make-up2..not engine transplant
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
yup... 3G83 turbo shared wif Mitsubishi Minica Dangan ZZ... comes wif 5 valves per cylinder!
  • Engine type — Inline 3 cylinder DOHC 15 valve intercooled turbo
  • Compression ratio — 8.5:1
  • Fuel system — ECI multiple
  • Power — 47 kW (64 PS) at 7500 rpm
  • Torque — 96 N·m (71 lb·ft) at 4500 rpm
but its not as powerful as the original engine 4A31 came with the Townbox/Juara. Not sure the Juara version used DOHC or SOHC :hmmmm: , I'll list them both
4A31 General spec
Displacement — 1094 cc
Bore — 66.0 mm
Stroke — 80.0 mm
Fuel type — Unleaded regular gasoline
1094 cc SOHC (1999)
[*]Engine type — Inline 4 cylinder SOHC 16v
[*]Fuel system — ECI multiple
[*]Compression ratio — 9.5:1
[*]Power — 58 kW (78 PS) at 6000 rpm
[*]Torque — 103 N·m (75 ft·lbf) at 4000 rpm
[/LIST]
1094 cc GDI (1999)
  • Engine type — Inline 4 cylinder DOHC 16v
  • Compression ratio — 11.0:1
  • Power — 54 kW (74 PS) at 6000 rpm
  • Torque — 100 N·m (73 ft·lbf) at 4000 rpm
dunno how you gonna get them though... :hmmmm:
Recently I check from the Perodua Service Centre regarding the Alternator price. They say is RM800+. Is it real that expensive? Because there is a weird sound coming out from my engine part, I just worry that after changing the alternator, the weird sound still exist from my engine part. Any Sifu here have any idea regarding this matter? Thanks.
