Mind telling me what is the use of a wastegate and does it directly increase power?? :emoticon_U:
alvin24: issit all aftermarket turbo dun have the wastegate?alvin24 said:wastegate doesn't increase power... just increases turbo response, and is more stabilized limiting boost.
STock torbo's also got internal wastegate... most aftermarket turbos don't have internal wastegate... which requires you to purchase and install an external wastegate.
black: so when u change gear, the sound is woi woi?BLaCkHoWLiNG said:fluff: imagine u have a twin brother.. .at the same EXACT instance, both of u shout WOI! ... so will u hear 2 wois or 1 loud woi...
alvin24 said:Difference between internal and external wastegate? One's inside, the other's outside... wahahaha... =Þ do a google search on photos then u'll know what they look like lor...
asianbookie,
blackie already said 'At the EXACT instance'... still u can come up with 'woi woi' ?!? hahaha... =Þ Wonder what will happen when one of the wastegate not tuned as tight as the other... or maybe one side wastegate rosak liau... the one will 'woi' earlier than the other... hahahaha.
"wooooowoooooooooooooiiiiiiiioooooooiiiiii"
Waahahahah
two at once ar? syok lor.. like WMP's 3D sound effect XDBLaCkHoWLiNG said:fluff: imagine u have a twin brother.. .at the same EXACT instance, both of u shout WOI! ... so will u hear 2 wois or 1 loud woi...
Thread starter | Similar threads | Forum | Replies | Date |
T | Of Gauges and wastegate | Car Modification | 14 | |
Recommanded Shop To Install Wastegate | Car Modification | 2 | |
A | 6A12 TT +wastegate | Car Modification | 29 | |
B | Help me !! AVCR ? WASTEGATE ? | Car Modification | 2 | |
A | Wastegate Function | Car Modification | 5 |
