Dear all,
I've been bothered by this for quite some time, as far as I know,
ignition advance would mean moving the ignition timing further away
from BTDC and retard would be getting it closer to BTDC. After
referring to most of the maps uploaded here, I've noticed that most,
or rather all the maps that I've seen had their ignition timing
retarded. I've sent my car for dyno tune recently and the tuner
advance all the timings from 3-6deg. I gained only about 2hp with
this setting. I'm driving a 4g18 SOHC NA Engine.
My question is, where do most factory ecu set their ignition timing
at with reference to BTDC? I've came across one article which says
around 10 - 12 deg BTDC. Since most(or literally all) of the maps
here had their timing retarded, I would also like to remap the
piggyback with retarded timing. Any advice on this?
Thanks
Jeff
Thanks
Jeff
