Doesn't look nice either...Looks odd...But then, it would be great if they sell such steel bumper protector. 1 thing is that,
it totally attached as your number plate holder...so not sure if it will look good. Yet is patented
WHY IS THIS BUMPER GUARD BETTER THAN ALL OTHER BUMPER PROTECTORS?
Made in America of Solid Steel
4Bumpers is the best solid steel bumper guard made in America. Indeed, based on our research we are the only
solid steel bumper protector made in America for cars. The steel we use is melted and manufactured in the southern
part of the United States and our U.S. based factory of steel fabricators brings form and shape to our U.S. Patented
design. Specialists in the New York metropolitan area complete the final process of powder coating and silk screening.
Now more than ever we need to support our economy and to that end we have committed to manufacturing 4Bumpers,
what we believe is the best solid steel car bumper protection, in America.
Quick and easy one time installation
Most of the time your 4Bumpers protector can be installed using pre-existing license plate screws. Unscrew the 2
or 4 screws currently holding in your license plate, align 4Bumpers with your license plate and bumper screw holes,
screw your 4Bumpers and license plate into your car, SUV or truck bumper and you are done. No additional bolting,
no peeling and sticking, no measuring or cutting films, 4Bumpers does not use elastic straps to hang on to the wheel
wells, or Velcro straps that purport to stick inside of your trunk. 4Bumpers requires no “flipping out” to use or “flipping in”
when you want to leave your parking space and, in fact, requires absolutely no additional handling after being installed.
Other products require handling else they don’t work. Lets be candid, nobody really wants to repeatedly handle dirty or
wet rubber mats or pads, and be forced to repeatedly place these products into and out of your trunk which holds your
clean and dry items. Once 4Bumpers is securely attached it requires nothing further and you can enjoy the peace of mind
and benefits of hassle free quality
bumper protection.
Great rear and front bumper protection
4Bumpers protectors easily attach through your front and rear bumpers’ license plate screw holes and is well suited
for any vehicle where license plates are in the bumpers. Further, and unlike 4Bumpers, many other bumper guards
were not designed for front bumper protection because of their need to use Velcro straps which are not safely suited
for use in the engine compartment. For the same reason Velcro straps are not safely suited for use in protecting the
rear bumpers of rear engine vehicles. 4Bumpers has no such limitations and works just great on front bumpers and
rear bumpers. Additionally, for example, rubber “welcome mat” type devices can veil over the license plate and drivers
should be aware that many cities and states have laws that make covering over or obstructing a license plate illegal
with heavy fines. 4Bumpers solid steel unibody design includes a license plate frame that does not obstruct or cover
over your DMV registration numbers or other vanity/custom plates. Even more, provided that your license plate is
located in the bumper and not above in the trunk or hatch, 4Bumpers was designed to be the first point of contact
with another bumper during parallel parking regardless of who does the bumping. As a result your car, truck and
SUV front and rear bumpers should remain looking great by being ding, chip and scratch free.
Sleek and Strong Design
Only after years of research and development did we arrive at our sleek, solid steel, unibody design. 4Bumpers isn’t
bent pipe or hollow tubes, it isn’t what some refer to as a rubber “welcome mat” blanketed over car bumpers, or a
rubbery frame, it has no welds, no screws and no Velcro straps. Quite simply and unlike other guards or so called
protectors on the market, 4Bumpers bumper guard has a sleek appearance that doesn’t detract from the look of your
vehicle. In fact, with our patented rounded guard design most might not even notice your 4Bumpers protection. On
the other hand, foam pads can rip, rubber tears, Velcro wears out, elastic straps lose their elasticity and these products
appear pretty dirty and worn over time which may be the opposite of what you intended for the look of your car, SUV or
truck. As for strength, 4Bumpers is solid steel!! And if a picture is worth a thousand words video is even more-check out
ours or other videos from the media to see how effective, strong and sleek 4Bumpers is and will be when protecting your
bumpers.
Protects your bumpers 24/7
That’s right, hassle free, maintenance free, 24/7 solid steel bumper protection by 4Bumpers. Why? Nobody
wants those unsightly, annoying and expensive to repair dings, chips and scratches we see on bumpers that
occur during parallel parking, a/k/a “the Bumperdemic.” And nobody wants to spend otherwise unnecessary
time in the snow, sleet, rain or blazing heat to protect their bumpers by being forced to deal with products that
require handling. Frankly, even when the weather is nice we want to park and simply go to our destination and
not park and hopefully remember to go around to your trunk and start “flipping out” a bumper guard, or worse
forgetting to “flip in” your bumper protector and instead drive around with that device flapping around and potentially
causing property damage to your vehicle-quite the opposite of trying to protect your bumper. Those manufacturers
even warn not to drive with their products because of the dangers of possible injury and death, YIKES! And yet if you
visit our Twitter page you will see many photographs of those very bumper protectors being dangerously driven around.
Good looking 24/7 protection makes infinitely more sense and unlike other “protectors” 4Bumpers has no danger of
touching and melting on your exhaust and, consequently, will not result in foreseeable and deathly fumes entering your
vehicle compartment. Your 4Bumpers guard will similarly not flap and cause property damage to your car bumper.
4Bumpers affords 24/7 parking protection and with no need to remember about handling or flipping another guard.
Instead 24/7 4Bumpers bumper protection quietly and simply protects your vehicle bumpers without a second thought.
Replaceable rubber edging
4Bumpers wants to prevent the “bumperdemic,” which are those annoying dings, chips and scratches that occur during
parallel parking. We also do not want to contribute to the bumperdemic. To achieve that goal each 4Bumpers guard includes
a rubber edge along the rounded guard area. This rubber edge protects the powder coated finish of your sleek 4Bumpers
bumper guard as well as the other car bumper. While we politely decline the periodic requests by customers to place spikes
or other perforating objects onto the 4Bumpers rounded guard (and at least one manufacturer does produce such a product)
we want to assure you that our goal is bumper protection. And when other bumper products tear, rip or wear out you are back
to where you started-lacking protection or a poor looking vehicle and bumper. Over time the 4Bumpers rubber edge can indeed
become worn through repeated impacts.Unlike other devices which wear and could require replacement at considerable expense, 4Bumpers rubber edge can easily be removed and replaced for just a few dollars providing your guard with that clean look again.
Source: Car Bumper Guard | The Best Solid Steel Bumper Protection | 4Bumpers-Protecting Your Car Bumpers
