Suzuki Swift: Airbag Signal Lights Up (goes off once in a while)
hitsugayat10
49
Hi :)
Just wanted to know if any Swift owners hav had the same prob and how to get it fixed?
Send the car to service centre n they said the "resistance" is high, prob is with airbag's ecu...
And to change that, cost RM2320 for a piece of airbag ecu :banghead:
Anyone sifus can gimme some advice ere? Thanks
ixeo
4,788
3,080
KL, Malaysia
i'm quite sure you can find half cut/chop shop airbag ecu for less than RM2320..
Hi
I've recently converted to vr4 240. The question is :
If my mechanic somehow salah pasang timing belt, can it cause my car to stutter at idle (jus like using high cam)
cause my car after the conversion at low rpm stutter and idles juz like using high cam. Driving at low rpms/speed is difficult becos of this problem. Checked the injectors , plugs,cable, timing, t/body etc but still the same effect. At high rpm okay but can here "tek tek tek" sound(like the valve's sound but im not...
