Suggestion for best rims size for Satria 1.3
thamo
118
MALAYSIA
Does anyone any idea the best rims size to use for satria 1.3 standard engine.
Please comment.Thank you for your comments
AJ6677
587
Melawati
used satria 1.3 before. if u want to look nice and cool go for 16 inch but u must remember it will be tremendously under powered. fuel consumption will suffer much. then u have to knock the underside of ur mudguard if not it will touch the body.....assuming u r lowering the car.
the best to me is the 15 inch....that's the usual size for satria 1.3.
thamo
118
MALAYSIA
i'm using 14 inch rim and lowered my car...so what size would be better ?
gavan
1,408
Shah Alam
well, depends on your liking, it could be 18 inches also if you want, butthen wether you like it anot, its your choice ;)
simon
292
the best would be to stick to the original maufacturer recommended size.....it would be mentioned in the driver's manual handbook . i believe the satrias 1.3 comes equipped with 13" rims . iam not sure if they have started to use 14" now for the Satria SE...for looks wise then bigger ones may look nice
muheez_17
297
I have used 17" inch on my stock satria before. Looks nice but then you got to knock your iner wheel arch then you will have problems when you lower the car.
After 17" inch i change to 15" inch and that suited me the best.
So i would suggest going for 15" inch on your stock satria.......
rabakshoe
365
yo bro
if ur hav lot of money go for 16inch wheels ah .. makes ur car more garang and cun ... but remember if 16inch u lose power n somemore ur tyre quite expensive then 15inch and below ..if you still wan 16inch then go for japan rims ah .. they are more durable and lighter ...
like me i used 15inch rims .. japan rims
quite ringan ... and i used the 55spec tyre ..
now my back tyre kene my fender ... later hav to go tyre shop put something at the suspension to make it higher a bit so that wont hit the fender
just my 2cents
Yong_5290
3,637
49
Klang
hotmail.com
i think 15" will be just nice...
get taiwan made 1 instead of cheapo JRD
those taiwan made r quite light yet durable
verticalimit
174
14"and 15" is the best choice. for me i go for 14". fuel consumption will be better if not size of the rim too big make the car under power really will suffer.
