how come both thread also dun have any text? zth facing problem again ar?
I dunno why can be like this....
My friend car have some problem when release the throttle...
When the car was moving rev it to high rpm (4 - 7,000 rpm), quickly put in Neutral and release the throttle. Then rpm will drop till less than 500 rpm then engine will stall.
But if driving very smooth and no violently drive, but this problem pulak. :hmmmm:
My bro also done check such as:
Ignition coil - confirm working fine
Spark plug - confirm working fine
ECU - already swap with another unit, still persist the problem
Vacuum hose - checked no found any leak
AFM - already change, still remain problem
My friend engine spec:
4AGZE block + 4AGZE intake manifold + SC14 + 4AGZE (AFM) ECU and wiring + 130ps 4AGE piston + 1.5mm metal gasket.
