Scooby sti version 8
denishsoh99
denishsoh99
219
Melaka
hi all sea fu....
i just belong my new ride(sti version 8 ) and im wondering to know some knowledge for boxer coz really a newbie in this...
**have replaced the cai to aps70,and full exhaust piping with trust down pipe and apexi drag muffler....
1.how much the stock engine of rpm i can go?cause the rev cut on 8k++
2.how much stock turbo & engine max boost in safety ..
*currently boost up to
9.8-1.0 bar when 1st -2nd gear , 1.1 bar-1.2 bar when 3rd - 6th gear...
3. im face turbo lag ,any advise to advoid??
4.any recommend to flash the stock ecu??and how much the budget??
im own a s15(sr20det)before,think is most easy to soup up compaire with boxer..really need a scoopy senior & seafu opinion..
:stupid:
DanzEterna
DanzEterna
15,913
3,371
3,213
PJ
www.primeperdanaclub.com
Re: Scoopy sti version 8
**do u have a shift light? if not can get 1 installed, set @ 6.5k rpm.
**best is to set it @ max 1bar.
** i tot you're using ball bearing turbines....shouldnt have much lag.
**not sure bro....try asking those tuner workshops in sunway.
AdamHurri
AdamHurri
Jul 1, 2010
26
503
Subaru's hv an in-built Shift Indicator. D Small button on d left of d Speedometer. As for maximum power is at 4,000 plus2 to 6k RPM. After dat d powerband simply drops. I set up d shift indicator to be at 5.5k RPM. Juz shift up when reach 6k. More than dat is redundant n will be detrimental to long term Engine Health. I'm using stock IHI VF42 Twin Scroll Turbo n boosting at max of 1.3 bar. As for Increasing the boost it is highly recommended dat u hv a proper Engine Management System to go along with it. High Boost=More Air. Therefore, AFR (AirFuel Ratio) is affected. Proper tune will get d desired AFR thus maximizing the power gain from Increased Boost n also preserve d Engine. There are many places where u can Reflash ur Stock ECU. Good ones are AE (Auto Enguinity, Ah Chai), RS Motorsport (Micheal), LMY Snailz Garage or better known as LMY (Andy), GT Auto Sunway..All are highly experienced in dealing n tuning wit Subaru Engines.
denishsoh99
denishsoh99
219
Melaka
--yes,stock already got shift light indicated,im set as 7k rpm
--is too hard to adjust fine maintaining boost(1.0) as will goes up when 3rd gear above cause im using manual boost controler..
--im suspect the cai aps 70 was effect to turbo lag,that why im use to reflash the ecu..
--is ok bro... im thanksfull for ur opinion...
:proud:
---------- Post added at 11:21 PM ---------- 6 hour anti-bump limit - Previous post was at 11:02 PM ----------
bro... u got the person contact of tuner?? cause im wish to know how much charges and how long to take times... im prefer to booking before im go...
---------- Post added at 11:31 PM ---------- 6 hour anti-bump limit - Previous post was at 11:21 PM ----------
since u r running 70mm aps cai, this etup required you to flash/piggyback ur ecu in order to reduce turbo lag since afr is affected.
if 65mm then its PnP
agree,.... that y im need all seafu to recommend me a better tuner and place...
im prefer to reflash ecu...
---------- Post added at 11:33 PM ---------- 6 hour anti-bump limit - Previous post was at 11:31 PM ----------
AdamHurri
AdamHurri
Jul 1, 2010
26
503
Auto Enguinity:- 03-5569-3028 Off
019-263-9560 Ah Chai (Tuner)
RS Auto/Motorsport:- 012-381-1717 Micheal (Tuner n Head Foreman)
GT Auto:- 017-387-3893 (Chew Soon)
For LMY unfortunately I dnt hv. Sorry
denishsoh99
denishsoh99
219
Melaka
BRO... JUST CALLED--
ah chai was do on road tune...cheapest prices..
michael say they dint do for reflash..
chew soon use dyno mechine...prices highest on road twice..
anyway thanks u very much...im consider which i have to go...
:biggrin::proud:
denishsoh99
denishsoh99
219
Melaka
finally im tuned at gt auto....
satisfied for result and prices too....
thaks adamhurri very much
---------- Post added at 03:43 AM ---------- 6 hour anti-bump limit - Previous post was at 03:32 AM ----------
.:driver:
