Satria 1.3 GLi Gearbox
simplythebest
1,978
Selangor
Hi all,
Something bad happened just now on my way home, i have got no idea why out of sudden my gearbox got this squeeky sound and 'tak tak' sound while shifting gears. Does this mean that the gearbox is dead? I like this gearbox alot, still can save ar? If not ..
1. How much does 2nd hand 1.3 GLi gearbox cost? roughly?
2. Can I use 1.3 Carb gearbox?
3. Installation workmanship labour?
4. What should I do with the faulty gearbox, can I sell it away to some steel shop?
GT Auto later in the afternoon (29/05/2005) got open ar? Mr. SDF please stand up, please stand up .. hailat liao, why the gearbox die at this time? :mad:
Thanks.
Hi guys,
That day on routine engine check, found my air filter hose connected to the turbine intake loose. The clip have been tighten to the maximum and still loose (moving). Was wondering what to use to tighten it up. The hose is rubber, so probably through the years of use could have harden and shrunk a little. The turbine is hot so cannot fit any rubber or paper, so was thinking what else can use.
So I raided my wife's kitchen for some "Diamond" brand aluminum foil. Fold a few rounds to...
