Remove thermostat
boyzone
2,669
38
5,148
Guys,
Is remove thermostat for injection engine is a good idea to gain better working temperature?
can share the Pro and Con ?:hmmmm:
Pls advise.. Thanks. :biggrin:
Adeen
2,726
6
kl
i think this topic already exists....u should search for it....
alot of feedback on the existing one..
boyzone
2,669
38
5,148
What I mean is water thermostat valve but not cooling fan thermostat :biggrin:
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
in my opinion,don't remove it.ur engine need a ideal temp to work best.
removing it will make ur car run to cold n ur fc will went up.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
"Thermostat is not just for cold starts, it is there to regulate coolant temp so that engine cylinder maintains within a temp. range for optimum combustion.
Engine efficency is at highest within certain temp range. (need to dig out my text book to remember those temp. figures)"-quoted by joeker the moderator
but it's true.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
besides, it will be harder to warm up ur car in the morning... coz the water/coolant will constantly moving... thus, warming up ur car will be hard in the morning...
most performance car will install low temp thermostat so it will activate at a lower temperature....
boyzone
2,669
38
5,148
ya, actually I'm look for low temp thermostat... but is quit hard for me to get the item in penang : (
Btw, which temp is the best range for low temp thermostat? pls advise.. Thanks.
DarkAccoon
880
432
3,063
here is my experience
driving towards KLIA at speeds of 160, temp went up to the redzone and air-cond kick off after just 5 minutes
starting up the car in the morning takes a bloody long time to heat up
was suspecting that my thermostat jammed
so go buy new thermostat for RM 25 at spare part shop
went and install it and to my horror, the previous owner of my car took away the thermostat and only left the skeleton there
after installing the thermostat, tried my luck towards KLIA again
constant 190, no problemo
temp constant at slightly below the middle bar
btw, me driving putra
HKS-GT2835R
1,193
83
5,148
kelate
i'm planning to drill out some small holes on my thermostat's body to help cooling. This way it'll allow the thermostat from ever being completely closed. it'll ensure constant coolant flow, and i'll still get the benefit of having a thermostat.
a pic of what i'm talking about.
boyzone
2,669
38
5,148
So, do u see the positive result after implement?:hmmmm:
any 1 can advise engine to swap into an Opel?
it's a FF , did read from foreign site, sr-20 , 3s-gte can go in.
but not sure wht did they done on the enjin
any 1 experience this or ur tuner modd and Calibra b4? kindly advise, thank you
