PM's Soundstream sales
ICE -In Car Entertainment
PowerMotion
Item(s):
Soundstream TRC.6 RM700 Highend Component
6-1/2" 2-Way Component System
Die Cast Aluminum Baskets with CNC Cutting
Aluminum Alloy Cone and Dustcap
Butyl Rubber Surround
Conex Spider
Chrome Plated Top and Bottom Plate
Vented Pole Piece
1-1/2" Hybrid Silk Dome Tweeter
Neodymium Tweeter Magnet
3 Mounting Options: Flush / Swivel / Surface or Angle Mount
Ferro Fluid Cooled Tweeter
18dB Impedance Compensating Passive Crossovers
Tweeter Protection
Tweeter Attenuation: -3, 0, +3 dB
Gold Plated Binding Posts
1-1/4" Kapton Voice Coil
13 oz. Magnet
Impedance: 4 Ohms
Grilles and Mounting Hardware Included
Crossover Dimensions: 6" L x 4" W x 1-1/2" H
Soundstream LW4.500 RM799 4ch amplifier 4x60RMS
http://www.soundstream.com/images/products/main/amps/L31.jpghttp://www.soundstream.com/images/products/main/amps/L32.jpg
4 ohms: 65 watts x 4 chan.
2 ohms: 125 watts x 4 chan.
4 ohm: 250 watts x 4 chan.
MOSFET power supply
LED power and protection indicators
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Variable unbalanced input level control
Dampening factor: >250
Soft turn-on circuitry
Preamp RCA outputs
DC, speaker short, thermal, and overload protection circuitry
Heavy duty aluminum alloy heatsink
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 15-35 Hz)
Dimensions: 11.42"L x 9.45"W x 2.52"H
Soundstream TRX4.300 RM1099 4ch amplifier 4x50RMS
http://www.cartuningevolution.com/Files/20108/8137113344546.jpg
4-Channel Tarantula series Amplifier
RMS Power @ 4-ohm: 50W x 4
RMS Power @ 2-ohm: 75W x 4
RMS Power @ 4-ohm Bridged: 150W x 2
THD: 0.05%
Class A/B Topology
Fully Regulated PWM Mosfet Power Supply
Tri-Guard Amplifier Protection
Bi-Linear Selectable, Infinitely Variable Crossovers for Inputs and Outputs (HP/Full/LP)
Platinum RCA and Power Inputs
Tri-Mode Capable
Hi Gloss Piano Black Finish
End Caps for Professional Installation
Variable Bass Boost
Dimensions: 11"(W) x 2.6"(H) x 16" (L)
Soundstream TRA960.4 RM1399 4ch amplifier 4x120RMS
http://s.lowyat.net/uploads//attach-88/post-211188-1234900670_thumb.jpg
NUMBER OF CHANNELS: 4
OUTPUT (WATTS):RMS @ 4 Ohms 120x4
RMS @ 2 Ohms 240x4
RMS Bridged @ 4 Ohms 480 X 2
T.H.D.: < 0.02%
Frequency Response (Hz): 10 - 50k
SIGNAL TO NOISE RATIO: >115dB
DAMPING FACTOR: >500
INPUT SENSITIVITY: 0.15 - 12.0V
CROSOVER SLOPE: 12dB
CROSSOVER FREQUENCY (HZ): 50 - 5k
DIMENSIONS (INCHES): 10.75x2.6x21.5
Variable hi pass, band pass, low pass
Variable 18dB bass boost
Double sided glass epoxy SMT circuit board
PWM mosfet power supply
Tri-guard amplifier protection
SMT cooling fan built in
Tri-mode capable
Line output
Package includes: Amplifier, mounting screws, fuses, manual, warranty card
Price:
TRC.6 6.5" 150watt component RM700 nett self import with 1 year registered warranty
LW4.500 RM799 self import with 1 year registered warranty or RM999 by MAT
TRA960.4 RM1399 self import with 1 year registered warranty
TRX4.300 RM1099 self import with 1 year registered warranty
Warranty: All with 1 year by Soundstream
Dealing method: COD/pos
Location of seller: Sri petailing or bukit jalil
Contact method/details: 016-3634000
Age of item: bvrand new in box..sealed
Item(s) conditions: 100% new, not used, not refurbished
Picture:
Reason for sale: just to earn some side income and offering you guys greater stuff
Yr LW4.500 Gen III best price how much? Been eyeing very long, need to upgrade my Mohawk amp. Let me know:banghead:
price in top there. already best offer. import set all sold off for the 4.lw500..left mat set only..
Bump: price in top there. already best offer. import set all sold off for the 4.lw500..left mat set only..
