Lower Arm Bar
VectorX2
268
45
528
Hi All,
Why is that a lot people would not recommend installing lower arm bars (front/back)?
Please Advice.
Thanks and Regards.
Danz, it's that tiny little stick that's bolted at the nut where mechs adjust the alignment. Right in the center.
Vector - my answer to Danz should give you a hint as to why it's not recommended. It messes with the alignment.
YYC
1,833
939
Front lower arm bar is not recommended for lower car... it will grind over everything that protrudes above the ground like humps.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
is it stabilizer bar ah? confuse here...got any pics in order for me to get a clearer picture?
---------- Post added at 09:56 AM ---------- 6 hour anti-bump limit - Previous post was at 09:54 AM ----------
i tot they adjust the tie rod & rack end for allignment...ehhe...
that one in picture i think ok maybe?? :hmmmm:
but the normal ppl install at lower arm screw point like most waja/wira rear is bullsh1t
i dun see any point installing it...
because the location of install was at the most toughest point in your car....that was where the chasis being the thickest and hardest..... i :rofl: when saw one installed in mostly protong cars.... :biggrin:
my rallycar and others track car also didnt install that thing.... :biggrin:
Yeah.. this bar isn't what they call the "Lower arm bar".
Anyway - this looks like the 4-pt mid lower bar?
risyia
168
30
3,028
Pandan Indah
UR & UTR - they both claim theirs are the original item, maybe last time same partners but now gaduh oready..
What I know, UR uses steel rods whilst UTR uses aluminium rods for their bars.
UR = Ultra Racing
UTR = Ultra Racing Development or something.
The story goes that they used to be partners blah blah blah. But the fact of the matter is UR was there first and have been in the market longer.
But a bar is a bar whether it's made by Tom, Harry or Joe. Just a matter of whether the bar fits nicely and is made properly or not. I heard CTech stopped making bars because of complaints or something. I might be wrong though but I haven't heard or seen CTech is a looong time
HI there all
jz ask u technical questions about the wira se car..im using stock 4g15 manual engine bought my car 4 months old..still brand new....
i wanted to mod to 4G's T engine dun care VR4, GSR or EVO1,2,3.....my questions is if i jz transplant the engine+ecu+wiring(or even +GB) ...do i need to change the radiator+aircond radiator to its own original respective engine?...or can i jz used stock wira radiator&aircond radiator?....
what about the power stereng pump?...aircond...
