if wanna remove swirl marks fully, then u need a machine to do it. meguiar's & 3M produces good polish & swirl mark removers which removes swirl marks very effectively. if ur swirl mark is not tat deep, maybe u can try using hand applied glaze's or machine applied glazes. glazes are oil based and they usually fill up the gap to reduce swirl marks.
some waxes can remove also, bcoz they contain detergents and some abrasive materials inside. by right, wax are not suppose to contain any abrasive material inside. they're just for protecting only, like Meguiar's NXT wax and 3M paste wax is 100% wax only, no abrasive materials.
munpeng, wat ur car painter say is true, using rotator will produce swirl marks, thats why a really professional detailer 1st uses rubbing compound, then from an aggresive polish to a less aggresive polish, then glaze, then wax. the key is to go from the most aggresive cut to the least. but depending on ur paint condition also. lets say if ur paint condition is not that bad, mayb can skip the rubbing compound, just start from polish.
Some info i got from the internet:
COMPOUNDS, POLISHES AND GLAZES SORTED BY CUTTING ABILITY
10 – MOST AGGRESSIVE - COMPOUNDS
3M SUPER DUTY RUBBING COMPOND HEAVY CUT 39004
MEGUIAR’S BODY SHOP PROFESSIONAL DIAMOND CUT COMPOUND 2.0 VERY HEAVY CUT #85
MEGUIAR’S BODY SHOP PROFESSIONAL COMPUND POWER CLEANER HEAVY CUT #84
3M PERFECT-IT III EXTRA CUT RUBBING COMPOUND 05936
MEGUAIR’S MIRROR GLAZE HEAVY CUT CLEANER #4
7
3M IMPERIAL MICRO FINISHING COMPOUND MEDIUM CUT 39001
MEGUIAR’S MIRROR GLAZE MEDIUM-CUT CLEANER #1
3M PERFECT-IT III RUBBING COMPOUND 05933
6
MEGUIAR’S BODY SHOP PROFESSIONAL DUAL ACTION CLEANER POLISH MEDIUM CUT #83
5
3M PERFECT-IT II RUBBING COMPOUND FINE CUT 39002
MEGUIAR’S MIRROR GLAZE FINE-CUT CLEANER #2
3M ONE STEP CLEANER WAX, MEDIUM OXIDATION REMOVER 39066
MENZERNA INTENSIVE POLISH
3M PERFECT-IT SWIRL MARK REMOVER DARK CARS 39009
3M PERFECT-IT SWIRL MARK REMOVER LIGHT CARS 39109
MEGUIAR’S MEDALLION PAINT CLEANER #97
MEGUIAR’S SCRATCH-X #108
4 - POLISHES
MEGUIAR’S BODY SCRUB A10
MEGUIAR’S DEEP CRYSTAL PAINT CLEANER #30
MEGUIER’S QUICK DETAILER #66
MEGUIER’S SPEED GLAZE #80
BLACK FIRE DEEP GLOSS POLISH
MEGUIAR’S BODY SHOP PROFESSIONAL SWIRL FREE POLISH LIGHT CUT #82
MEGUIAR’S MIRROR GLAZE SWIRL REMOVER #9
3M FINESSE-IT II MACHINE POLISH 39003
3M FINESSE-IT II FINISHING MATERIAL 05928
MENZERNA FINAL POLISH
2 - GLAZES
MEGUIAR’S BODY SHOP PROFESSIONAL HAND POLISH VERY LIGHT CUT #81
MEGUIAR’S MIRROR GLAZE MACHINE GLAZE #3
3M PERFECT-IT III TRIZACT MACHINE GLAZE 05930
3M PERFECT-IT III MACHINE GLAZE 05937
3M IMPERIAL MACHINE GLAZE 05991
3M ONE STEP CLEANER WAX, LIGHT OXIDATION REMOVER 39006
MEGUIAR’S MIRROR GLAZE SHOW CAR GLAZE #7
3M PERFECT-IT III FINISHING GLAZE 05941
3M IMPERIAL HAND GLAZE 39007
BLACKFIRE ALL FINISH PAINT PROTECTION
MEGUIAR'S NXT TECH WAX
3M PERFECT-IT SHOW CAR FINISH PASTE WAX 39526
Maybe some simple definitions:
Compound - a heavy abrasive used to remove surface imperfections
Polish - a light abrasive used to remove surface imperfections
Glaze - an oil based product used to fill surface imperfections and create gloss
Wax - a product to protect the paint surface
7
6
5
4 - POLISHES
2 - GLAZES
