Budget RM15-20
Ingredient
1)AA battery pack Doorbell magnetic type: 1 unit
2)Normal LED cable (60cm): 2 unit
3)LED(RED/blue) : 1 unit/more
4)Paper Clip: 0.5cm long(cutout)
5) wire tape, both side tape
*Doorbell
1)remove the cover, unplug the battery slot and extend the existing wire with Normal LED cable(black to ground, red to power).
2)Extend the cable of the magnet so that you can attached on the rear panel of your speedo
3)solder the LED(RED/blue) on the LED cable and solder both end on the speaker of the doorbell (make sure the position of +- is correct)
Installation
1)Doorbell= connect those 2 cable from battery slot (black to ground, red to power)
2)LED= Anyway... Dashboard, pillar, bosskit
Remove you dash meter and attached the extended magnet piece on the rear of your speedo (Say 4000rpm gives be best result then attached the magnet on the back of the panel- cun cun 4000rpm)
glue your speedo needle with small piece of paperclip... then put everything bacl in order.
HIhi..here's your DIY a shift lamp + bell Alarm *Bonus. which means when your speedo hit 4000rpm your LED start blinking and Alarm goes Ding~dong Ding~dong takumi feel.
Hope u like my crazy idea~~
