How to clean to mark?
singchaii
687
Pandan Jaya, KL
Hi guy.. recently I just removed those custom sticker on my rear windscreen(outside). After remove the stickers, it had mark on the windscreen. I had try to clean it using window soap and car shampoo.. But the mark seem not removable.. How to remove those mark? T
singchaii
687
Pandan Jaya, KL
use polish...
if still cannot remove the mark..use thinner
Polish also can?
I had wipe it off and now is visible.. But when pour water, it have the water mark exactly the sticker design there.. can i clear it also?
use zippo lighter fluid or thinner.u can use wd40 too.
szekeiemme
3,749
5,138
try spray soap water n use blade n slide de glass.. it will remove anythin ehehe..
singchaii
687
Pandan Jaya, KL
I wonder why some sticker will have glue on it.. Izit because of low quality? While my some custom made sticker very nice.. When take off, nothing will stick on the windscreen.. Why finally I done all the mark.. I bought a tin of sticker remover at accessories shop.. Spray on the sticker, it will remove in few seconds.. Nothing left on the windscreen. After done it, then use Rain X to wipe the windscreen. Hehe.
Aug 29, 2007
how about our locally made road tax? it is pasted inside the windscreen, not outside... sometimes when take out that time very hard, and if take out already, some stickiness will be left..
wat to do? If use thinner, will it affect our tinting film? hmm
CarroTT
177
spray degreaser on the mark,then use ur finger and rub rub rub, sure come out wan, very efektif :biggrin:
tatayoung
401
7
fuys.. i had the same problem.. removed a sticker.. and what happenned after that is i used a sponge to scrub the dirt off.. result..? there are some pretty deep scrathes remaiming.. due to the sponge..
what do you guys suggest.?
how do i make em scrathes go away..?
cdraculla
40
Yeah, WD40 or Silicon spray absolutely work. Last time, I had a marker pen ink on my windscreen (transfer from car sticker) and I used Silicon spray, all gone. Two days ago also got glue stick on my bumper and I used WD40, also gone. So, you can choose either one to solve urs :-)
frank118
435
24
Zippo lighter fluid with a soft towel and then any cleaning liquid with newspaper...it worked for me.
dudes, my mom's perdana executive also the auto gearbox koyak la.............
spent about 3K plus to buy 2nd hand gearbox but still not cekap la.......
when accelerate from stationary, have to do it very slowly otherwise the gear will jump from 1st gear to 2nd n got load thud sound.........
anyone can give me any advice?
what can we do to get rid of this problem?
we just replaced the shock absorbers n both upper n lower arms on both sides so now only the gearbox is a main...
