how do you know when to change car's battery
weikhee86
423
when should you change your car's battery? some people said once every 1 and a half year and some people said 2 years...how do we know when is the right time to change battery? i'd lots of nasty experience in which the battery died suddenly at the wrong place at the wrong time...please help guys...
acbc
4,615
8
KD
Keep a battery tester around. Check every month. If voltage falls below 12V, it's time for replacement.
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
acbc
4,615
8
KD
My E32's batt is already 5 years old... n still alive. I think know why... it is located under the rear seat where it is cooler n completely protected from the elements.
weikhee86
423
voltmeter fix in the car as additional gauge izit? alternator want to replace expensive o not?
[s]UpErNoVa
313
about one an a half to two years change once.. de best way to notice if ur car battery is weak or not is turning on de headlight brightness.. if it dims tat means de battery has no enough power oredi.. cheers!
gloss
1,546
SJ
or you can fix a VS with indicator to ur battery ...
hehe.... :p
volt meter do help also..
weikhee86
423
hey does faulty VS harm the battery? need to know guys..i got VS but in doubt whether wan to pasang o not
acbc
4,615
8
KD
Yup! 5 years... still using the 1st gen MF batt - price tag = RM 450 (AC Delco).
acbc
4,615
8
KD
Speaking of voltmeter, I just constructed one from a hobby kit using 10 row of LEDs. Will install it tmw.
Hello seniors,
I would just like your advice on clutch item.
If lets say we made a clutch replacement. I read an article that mentioned clutch "run in" at 1000km.
May I know what is it?
TQ.
