- Joined
- Nov 15, 2003
- Messages
- 22
- Points
- 3,001
Do i need a top mount manifold if i would like to mount my turbo
topside?
Thanks!
topside?
Thanks!
superfunhappysliders said:more importantly your feeling of "lag" generated by the manifold itself isfrom the way the pipes are joint. Equal length exhaust runners help make sure that the turbo is spooled evenly. On my manifold we also made sure we accounted for the cylinder combustion pattern (ie an RB engine dosen't just go 1-2-3-4-5-6 and loop, it goes 1-3-5 2-4-6 or something like that) so what you do is you have to sets of runners feeding into your turbo flange (instead of them all joining up together and then into the flange with a seperate pipe). This means there's ALWAYS going to be exhaust going through it. If spool is an issue on the larger turbo a very obvious fix is to get a smalled exhaust housing on the turbo, so less revolutions are required to force the air in the compressor housing. Some top end power is sacrificed though.
performancewerkz said:Do i need a top mount manifold if i would like to mount my turbo
topside?
Thanks!
Similar threads | |
