GTi vs Putra std springs.got diff?
adrianlek
adrianlek
303
sgor
my putra std springs make my car ugly cause damn high.dont like the ride if change to sport springs.
so i was wondering how my car would look if i change to GTi std springs.i notice GTi's are lower than any other normal satria/putra/wira even in std form.
can anyone tell me how much is it lowered?how bout d ride? bumpier than stock putra springs?i wanna b very sure cause i just changed new absorbers.i takut it dont match then my new absorbers kong :eek:
thanks
tajulsans
tajulsans
1,449
9
Soo Bang
thanks
Did u notice the diff of the rear end for both cars?? the GTI rear ones are made softer.. not recomended. ur car will look like kapal..
G_ti
G_ti
58
1,508
Hi , Tajulsan ...
Why you say rear springs a softer for GTI ?
Andrianlek ,
Actually , GTI is lowered equally and fully balanced from front to rear , but some says front it higher then rear . This is because of the spacing betwen tyre and the chasis for the front is higher due to the engine is heavy . . As all knows that GTI are well known of it's LOTUS handling and it's great when you rev when cornering . The truth is both springs are very hard and GTI springs cannot be used for confort riding but it is very good for handling .
For a Putra , i don't suggest GTI springs , because PUtra weight much more lighter then GTI . If you put in a hard spring on a light weight car , then it will be a very hard riding and the whole plastic cover inside your car will produce uneasy sounds . :angry_smile: :angry_smile: :angry_smile: 1 of my friend using eibach lowered spring for his putra . It look lowered but still a hard ride .
G_ti
G_ti
58
1,508
aquila ,
Big does'nt mean heavy . Putra can be pushed by 1 person but Gti is very hard to push by 1 person . If you don't belive try to push 1 putra and 1 GTI . You can feel the difference already . :_: :_:
east
east
107
Well u can try putting SGTI spring into your Putra but u wont have a good ride. THe reason is because SGTI spring is hard and it is not design for comfort. It is more toward handling rather then comfort. Trust me because im one of SGTI owner. When comes to bad surface u can feel the car spring make your car kind of hard when going through those kind of surface. but if u plan for handling then go for it. if u think of comfort then forget about it.
zan
zan
2,154
specs for SGTI and part number
514 [Green/Cream] Suspension Spring Front ...MB808296...RM 75.73
515 [All] Suspension Spring Rear..................... PW567325...RM 83.58
463 [KYB] Shock Absorber Front RH................. PW567319..RM 367.65
464 [KYB] Shock Absorber Rear....................... PW567326..RM 139.31
for Putra - standard non-Evolution spec
478 [All] Suspension Spring Front ...................MB808296...RM 75.73
479 [All] Suspension Spring Rear.................... MB809273...RM 51.09
431 [All] Shock Absorber Front RH.................. PW530244..RM 238.76
432 [All] Shock Absorber Rear........................ MB809270....RM 98.01
putra and SGTI shares same stock front spring. but the rest is different - rear springs, absorbers even stabiliser. (thicker for SGTI)
i hope this info helps.
aquila
aquila
271
SA
G_ti said:
aquila ,
Hmmm... wouldn't mind someone sponsor me their SGTI so that I can push and find out myself too ;)
I think having a bigger rim is also harder to push. Didn't know SGTI got additional sound proofing... Well, at least now I know...
zan
zan
2,154
EjaT3000 said:
Zan.. where u get the price. U sell it?
heh heh heh no lah. i dont sell things. search internet onli
aquilla, SGTI is the best proton as it was modified by Lotus in house. the project came during Tan Sri Yahya Ahmad in charged of Proton before the helicopter crash.
try a ride in standard SGTI and you would find it quiter than other protons. other than extra sound deadening materials, the result also comes from modified intake chamber. that was the only thing Lotus was allowed to do on the power train due to budget perimetre.
aquila
aquila
271
SA
Ic ic... I only tot that SGTI only had Lotus tweak the handling with the suspension setups and the anti roll bar... Didn't know about manifold and the sound proofing stuffs... Now I know :) Maybe I should try sound proofing then...hehehe
